Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
whats the best synthetic MTG on the market
Old Jul 1, 2006 | 12:03 AM
TopSpeedNY's Avatar
Any Clues better then amsoil mtg cause i want to order something else i believe there are better ones synthetic MTG'S thanks.
Mike
Old Jul 1, 2006 | 05:11 AM
Bobo's Avatar
What is MTG? Manual transaxle gear oil?
Old Jul 1, 2006 | 01:07 PM
TopSpeedNY's Avatar
yep Bobo its Manual Transaxle gear oil. any clues?
Old Jul 1, 2006 | 04:33 PM
Bobo's Avatar
I have a 5-speed and, quite frankly, I couldn't be bothered switching to synthetic gear oil. A lot of members seems to like Redline MT90 for a synthetic gear oil.
I would be more inclined to use synthetic transmission fluid in an autotragic, but I've never owned one.
Old Jul 2, 2006 | 01:36 AM
TopSpeedNY's Avatar
what about mobil synthetic do they carry that i know only dino and for synthetic amsoil, valvoline, lucas,red line. Thats about it I know any other brands ?
Thanks.
Mike
Old Jul 2, 2006 | 07:56 AM
Bobo's Avatar
I haven't heard of Mobil synthetic.
If you truly must go synthetic, go Redline MT90 and quit wasting your time.
Life is too short to be so ****!
Old Jul 2, 2006 | 08:12 AM
RA030726's Avatar
I'm nutty for Nissans
I dont think the Mobil is GL-4. You can only use GL-4.... do not use GL-5 becuase it will wear out the syncros.
I had MT-90 in my stock tranny. It was fine, but I didnt notice any difference.
It started leaking so I topped it off with cheapo GL-4 from NAPA. Its thicker thats for sure. Still no real difference in shifting IMO.
I am now running Amsoil synth. And its really thin. I do like it, but then again its in my new(er) tranny. Im sure both synthetics last longer and protect better. Worth the money? Who knows.
I have also tried MT-90 mixed with MTL, and that was fine too.
Basiclly just go out and buy what ever you like, but make sure it doenst say GL-5 anywhere on the bottle.
Old Jul 2, 2006 | 08:35 PM
TopSpeedNY's Avatar
Okay i have found out that some mobil synthetic transmission oil is 75w90 please confirm from this list:
PVL & CVL - GEAR OILS
Grade Name SAE Viscosity Grades API Other
MOBIL GEARLUBE VS 500 (Synthetic) 75W-140 GL-5 BMW Limited slip differentials
MOBIL GEARLUBE VS 600 (Synthetic) 75W-90 GL-5 BMW Conventional differentials
MOBILUBE 1 SHC
(Synthetic) 75W-90 GL-4
GL-5
PG-1
PG-2 MAN 3343 SL Scania
STO 1:0
MOBILUBE PTX (Synthetic) 75W-90 GL-4
GL-5 Porsche transaxies
MOBILUBE SHC 75W-90 LS (Synthetic) 75W-90 GL-5 Limited slip axles
MOBILUBE SHC 80W-140 ID (Synthetic) 80W-140 GL-5 Eaton & Rockwell axles
MOBILUBE XHP
(Semi-Synthetic) 75W-90
GL-4
MOBILUBE GX 80W-90 80W-90 GL-4 MAN 34 1N
MOBILUBE GX 80W-A 80W GL-4 MAN 34 1N
MOBILUBE HD 85W-90-A 85W-90 GL-5 MAN 342N
MOBILUBE HD Series 80W-90,
85W-140 GL-5
MOBILUBE LS 85W-90 GL-5 Limited slip axles
Old Jul 2, 2006 | 08:37 PM
TopSpeedNY's Avatar
here is a link that mobil delvac 50 synthetic mt-1 gl-4 as well
http://www.imperialoil.ca/Canada-Eng...s_Fluid_50.pdf
Old Jul 2, 2006 | 11:51 PM
SilverMax_04's Avatar
You do not want to use a fluid that is GL-5/GL-4. You should only use a GL-4 fluid. Both Amsoil and Redline make this synthetic GL-4 fluid in the proper weight. I'm running Redline because when I changed fluid last year, Amsoil had not reissued the GL-4 line that it had earlier dropped. I'm certainly happy with the Redline, but expect I would have also been happy with the Amsoil if I could have gotten it when I needed it. Check out the stickies on how to do this change yourself -- you will also find other valuable info in that thread.
Based on the Imperial Oil specs for the Mobil synthetic fluid you are considering, it appears that it too is a straight GL-4 fluid. The specs also say that the Mobil fluid is a lighter weight (SAE 50) than the Redline product I am using (SAE 75W90). In Canada you may want the lighter fluid to handle the colder weather. Down here, I will stick with the heavier fluid in my trannie where I frequently drive where summer temps are over 100 degrees F.
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
Maxie40
Sep 14, 2015 11:28 AM
