Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
fuel injectors?
Old Aug 27, 2006 | 01:44 PM
Tone8969's Avatar
fuel injectors?
is the "induction service" at the dealer the only way to clean the injectors for the 3.5L? or can i run a bottle of seafoam thru the gas tank?
03 3.5L pushin 60k miles.
Old Aug 27, 2006 | 05:49 PM
Bobo's Avatar
Why don't use just use Chevron Techron, LubeControl FP60, Gumout Regane or BG44k?
I wouldn't run Seafoam through anything other than a brake booster cable to clean out the intake manifold and I have never done that.
Old Aug 27, 2006 | 06:11 PM
steven88's Avatar
Need A Light?
agreed...i would reserve seafoam for the intake manifold...auto-rx for the crankcase...and chevron, gumout regane, or redline si-1 for the fuel tank...
Old Aug 28, 2006 | 06:02 PM
mbschnei's Avatar
gumout worked well for me
Old Sep 3, 2006 | 11:08 AM
Tone8969's Avatar
we only run the premium grade chevron w/techron thru the car... whens it best to dump one of the mentioned above into the gas tank? full, half, near empty? DOes it even matter?
Old Sep 3, 2006 | 01:36 PM
SilverMax_04's Avatar
Don't use the cheap Gumout (which is made for carburators). They supposedly have a more expensive cleaner that works well for fuel injection.
You should put a bottle in your fuel tank just before filling up (good to be down to about a half tank) and the gasoline pumped into your tank will mix the cleaner into the gasoline so you don't get a slug of cleaner in the fuel system. Be certain to get enough to give a proper treatment rate for your gas tank when full (probably 20 gallons).
I prefer the Chevron Techron, but there are supposed to be others that are as good. I can't recommend anything but Techron.
Old Sep 3, 2006 | 02:28 PM
Tone8969's Avatar
Ok, ill pick up a bottle of the Techron stuff and give it a shot. Thanks.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
