Any One used Neo Gear Lube 75w90 oil expensive...
Neo Synthetic 75W-90/RHD Gear Lube
100% Synthetic Base for Extreme Temp & Wear Problems
Key Features:
* Exceptional Thermal Stability
* Excellent Shear Stability
* Lower Operating Temperatures
* Reduce Wear, Greater Parts Life
* Seal and Gasket Compatibility
* Excellent Low Temperature Flow
* Outstanding Power Transfer Performance
* Excellent High-End Racing Use
* Best Gear Oil in Racing
Used in F-1, IRL, Champ Car, ALMS, NASCAR, Grand-Am, SCCA, NHRA
NEO even increases fuel mileage in tow vehicles
I've heard of this oil. This is from their website.
APPLICATIONS.
NEO 75W-90 HD Gear Lube exceeds the requirements of auto specs GL-2 through GL-5 and military specification MlL-L-2105E.
NEO 75W-90 HD meets the requirements for GL-4 grade even where manufacturers discourage the use of a GL-5 product. It is recommended for front wheel drive transaxle use where GL-4 performance is specified.
Common vehicle drive train components needing NEO 75W-90 HD are manual transmissions, drive axles, differentials (including limited slip differentials), transaxles, auxiliary transmissions, transfer cases, overdrives, and final drives.
Industrial equipment applications for NEO 75W-90 HD include gear boxes for conveyors and similar assembly line drives.
Gear boxes using this type of lubricant typically do not need any break-in period on petroleum lubricants. The NEO 75W-90 HD can be used as a direct replacement at any time.
NEO 75W-90 HD gear lube will mix with petroleum products; it is not necessary to flush the gear box first. However, mixing a large amount of petroleum with NEO synthetic will dilute the qualities of the NEO and will shorten the service life. This is not recommended. Using aftermarket additives is not necessary and may produce unpredictable results. Use of aftermarket additives voids the NEO warranty.
APPLICATIONS.
Maxima.org Sponsor and Donating Maxima.org Member
If you go with a combo rated oil, change it at least every 60K miles to make sure the buffers are fresh.
Originally Posted by TopSpeedNY
Used in F-1...
Originally Posted by CCS2k1Max
If you go with a combo rated oil, change it at least every 60K miles to make sure the buffers are fresh.I changed my original factory fill of trannie fluid at 30K miles -- wish I had done that sooner. I will likely change the synthetic fluid now in it at about 80 K miles. The fluid is cheap versus trannie repair, and the change is not that hard to do, having done it once and now owning the right funnel.
05RLS2
Apr 14, 2016 11:49 AM
