Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Clutch/Brake fluid weirdness
Old Nov 5, 2006 | 10:03 PM
oTranscendental's Avatar
I recently filled up both my clutch and brake reservoirs with Valvoline SYNPOWER fluid which is supposed to exceed dot 3 and 4.
I noticed in the pedal feel of both that there was a crunchy feeling to it. It seemed to happen at the moment of maximum fluid compression. I have SS lines on the clutch and on the front Z32 calipers.
Whats with the crunchy pedal feel? I can actually hear the noise especially from the brakes. My assumption is that the synpower and the oem fluid don't mix well and create this nasty pedal feel.
It makes my brakes feel like a downgrade rather than an up grade.
Old Nov 7, 2006 | 11:37 AM
anyone got an idea?
Old Nov 7, 2006 | 11:58 AM
mm03's Avatar
Clutch squeaking
Sorry can't help but can someone help me. My clutch squeaks when pressing and depressing. What can I do to fix? I think I need some lubricant on it, can someone show so where if needed.
Old Nov 9, 2006 | 05:12 PM
THats the pivot point on the pedal. Get some wd40 and spray it. Look under the dash and you will see the pivot.
Old Nov 12, 2006 | 05:39 PM
bump 10char
pktaske
May 6, 2016 07:49 AM
Need help
23
Oct 2, 2015 08:56 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
pktaske
Sep 4, 2015 08:40 AM
