Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
which antifreeze and red line water wetter
Old Jan 7, 2007 | 06:56 PM
absoundlab
I have a 2000 maxima 3.0L and I want to do a rad. flush. there is green in there now. what brand fluid and what should I put back in there. Also has anyone tired red line water wetter. If so how well does it work
Old Jan 7, 2007 | 06:59 PM
jmeister's Avatar
http://forums.maxima.org/showthread.php?t=278600
happy reading
Old Jan 8, 2007 | 06:08 AM
MIXXMAX's Avatar
I use Toyota Red and I'm very pleased with it. Never had any problems with it. It's slightly less expensive than Nissan green. I never did like Prestone. It doesn't suit well in Nissan's. Most Prestone brands have silicates in them causing damage to water pump seals. Unless the coolant is silicate free, you shouldn't have any problems.
Old Jan 8, 2007 | 07:02 AM
absoundlab
do you buy the toyota red from toyota or do you buy it at the parts store
Old Jan 8, 2007 | 08:16 AM
MIXXMAX's Avatar
You have to buy from the Toyota dealer.
Old Jan 8, 2007 | 07:30 PM
irish44j's Avatar
retired moderator
Toyota red, FTMFW.
Old Jan 9, 2007 | 05:36 AM
absoundlab
what about the water wetter has anyone used it?
Old Jan 9, 2007 | 09:38 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showpost.ph...84&postcount=1
http://forums.maxima.org/showpost.ph...18&postcount=7
http://forums.maxima.org/showpost.ph...6&postcount=12
Old Jan 10, 2007 | 12:18 PM
kcryan's Avatar
No water wetter, nissan designed this car to run the way it does, they are a heck of a lot smarter than we are, not to mention that that stuff has a great habit of forming black goo in cooling systems
Old Feb 2, 2007 | 08:15 PM
00MaxSE's Avatar
Pointy Elbows
Originally Posted by irish44j
Toyota red, FTMFW.
Old Feb 7, 2007 | 01:08 PM
Colonel's Avatar
Old Fuddy Duddy
Originally Posted by 00MaxSE
Whatever you use, make SURE its silicate free.
Old Feb 20, 2007 | 08:33 PM
96blkonblkse's Avatar
toyota red FTW. best stuff ive used. Im not usre if you guys are aware, but when you get your car serviced at nissan, you are getting generic coolant, which is bought in bulk and we put it in our own bottles? Thats why ill only use toyota red.
Old Aug 21, 2007 | 04:15 PM
madoleh's Avatar
Laughing at the RX8 people... Reviving this thread
If you want to laugh a little at the Mazda (in reality, Ford) people, check out this link
http://www.rx8club.com/showthread.php?t=124981
Old Sep 2, 2007 | 05:02 AM
redls1's Avatar
MAXIN' ON
I just changed my fluid to the 40 degree below stuff with soe radiator fluid as t not freeze and a bottle of water wetter in the reserver tank. Will measure temps later.
Old Sep 2, 2007 | 07:08 AM
Kevlo911's Avatar
Kevlo for President
Toyo red and water wetter is what I used. But all this info is in the giant sticky so no need for this thread
Old Sep 2, 2007 | 11:03 AM
andrei3333's Avatar
Nissan OEM Long Life coolant only, designed to be used in YOUR particular car btw
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
