Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
can I use 10-40 weight oil
Old May 3, 2007 | 01:00 PM
nitink's Avatar
I am wondering if I can use 10-40 dino motor oil in california.
I normally use 5-30 in winter & 10-30 in summer. will using 10-30 cause any problem.
Oil is havoline 10-40 DS.
Old May 3, 2007 | 02:04 PM
CCS2k1Max's Avatar
Absolutely. It won't harm anything other than the wallet as you may lose a bit of gas mileage.
Old May 4, 2007 | 02:53 PM
SilverMax_04's Avatar
As long as you don't try to start your car when its cold and the temperature is below about 32 degrees F, you should have no problem.
Normally you would only want to use motor oil that heavy when you are driving in very hot conditions (temps above abour 90 degrees F and often up above 100) or your engine was worn and you wanted to try and decrease oil consumption by using a heavier motor oil.
So the question is, why do you want to use oil this heavy?
Old May 4, 2007 | 03:17 PM
nitink's Avatar
I am in california and we never run into sub zero temps. Only reason I was looking for 10-40 is that I am out of 10-30 oil have 10gallos of 10-40 available @ hand.
Old May 5, 2007 | 11:46 AM
sky jumper
use it. you will be fine. as it is dino it might even shear down to a thick 30wt anyway.
Old May 5, 2007 | 05:08 PM
Love_00_Max's Avatar
Havoline DS seems to thin out unlike their old formula which is good if you are going for 10W40.
VQs seems to like thicker oils, I was on 10W30 for a very long time but recently switched back to 5W30 since they all cost the same. There was no improvement in MPG.
Old May 6, 2007 | 04:48 AM
2002 Maxima SE's Avatar
You could mix it with a thinner oil, just to be safe.
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
