Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Bg44k
Old May 16, 2007 | 07:06 AM
Bobo's Avatar
Bg44k
Has anyone used the BG44K fuel system product?
I know it contains a solvent and wonder if it would do any harm to the engine/fuel sytem.
How much fuel should be added to the 11 ounce can?
It strikes me that it would be more effective if a whole tank of gas wasn't used.
Where is kcryan when I need him?
Old May 16, 2007 | 09:36 AM
00MaxSE's Avatar
Pointy Elbows
I have used it 2 times. I just added it to the tank then filled it up.
Old May 16, 2007 | 04:47 PM
maximadave's Avatar
detailerdaveb@gmail.com
I used it twice...worked great
poured it in on an almost empty tank and filled it up with Chevron 91
Old May 18, 2007 | 07:18 PM
Mints33's Avatar
Used it once in each of the vehicles, van and max, poured it in w/ 1/4 tank of gas, added BG, then filled up. To be honest, I don't know if I really noticed a difference.
Old May 19, 2007 | 06:24 AM
MichMaxFan's Avatar
I was a bit hesitant to use it after reading up on it because it is quite a STRONG cleaner. But, my van had 2 occasions close together of fuel injector issues, running crappy as if on 4 cylinders instead of 6 and SES light coming on. I got the code cleared twice, put in the strong BK44K stuff and the light never returned, atleast so far. Smoothed the thing out, too. I have heard that if you use it, don't do it more than once a year or so since it is quite strong. I have not used it in my Max, and not planning to. I use the less strong Chevron Techron, and cheaper since it doesn't have the problems my van had. I think I'd use it if you got rough running problems, but not often.
Just my $.02.
Old May 19, 2007 | 08:33 AM
Bobo's Avatar
I have also posted a thread on BITOG (www.bobistheoilguy.com) and have decided that I am going to hold back on using the BG44K on the Maxima.
I don't think I need anything this strong at this point in time (68K mostly highway miles).
I am going to look into getting some Schaeffers 131 Neutra which is a fuel additive that supposedly will help clean the EGR system and minimize the risk of the carbon buildup that sometimes needs to be scraped out manually.
Failing that I will just use some Chevron Techron in December before I go through emissions testing.
However, I understand that Chevron Techron isn't readily available in Canada anymore, at least at Chevron gas stations and they don't sell it at Canadian Tire.
Old May 19, 2007 | 11:54 AM
TurTLe*'s Avatar
i used to put it in every other week, when i had a big supply of it. i cant think that i acutally saw or felt a diffrence in MPG.
Old Jun 5, 2007 | 04:09 PM
rays05maxima's Avatar
It's already been stated above, but pour the entire contents on a nearly empty tank and fill up. The jury is still out on whether it makes a difference or not. I've had decent results, but I've always used chevron techron.
kevmor99
Oct 12, 2012 10:15 AM
delguiner
Feb 1, 2007 05:28 AM
SE4KIMMY
Mar 12, 2004 08:55 PM
Dawgs AE
Nov 25, 2003 01:55 PM
JsL
Feb 14, 2003 06:41 PM
