Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Going back from synthetic oil to regular
Old Dec 21, 2007 | 01:21 PM
Y2KMaxGXE-R's Avatar
What is the proper procedure of going from synthetic oil back to regular? Is engine flush needed? My friend bought a used vehicle and prev owner used synthetic.
The vehicle has about 20k mi, it is a 2007 Hondah CR-V.
Old Dec 21, 2007 | 03:20 PM
lightonthehill's Avatar
I have never made this switch, but when going the other way, all I have ever done is just have the engine oil drained normally. You certainly must have the filter changed when switching between oil types. If it makes you feel more comfortable, you could change the oil again after just another thousand miles or so, in order to get most of the rest of the synthetic out, but I never bothered with that.
Old Dec 21, 2007 | 03:28 PM
mtrai760's Avatar
'Trynna' is not a word
Just do a regular oil change and don't worry about it, it's not going to affect anything.
Old Dec 21, 2007 | 05:28 PM
thanks for comments guys
Old Dec 22, 2007 | 06:32 AM
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Out of curiosity, what's prompting his decision to go back to petroleum oil?
Old Dec 22, 2007 | 07:55 AM
RW-Maxima's Avatar
Agree with just do an oil and filter change. They 2 are compatible, for instance if you're on a road trip and have to top off -- of course, that's not ideal.
Old Dec 22, 2007 | 05:15 PM
VEvolution's Avatar
I miss my VE
Probably wants to waste more natural resources, do more frequent oil changes, and reduce the life of the engine?
Old Dec 22, 2007 | 09:33 PM
Scottwax's Avatar
That's Mr. Detail to you
If it causes global warming and no more freezing temperatures ever in Dallas, I am all for it. Seriously.
Old Dec 23, 2007 | 10:06 PM
VEvolution's Avatar
I miss my VE
Same here for NY..
Old Dec 30, 2007 | 12:55 PM
d00df00d's Avatar
Old enuf to pick his own gears
Just so you know, the end result of gobal warming would be an ice age.
Old Jan 16, 2008 | 02:35 PM
NismoMax80's Avatar
SuPeRmOd
global warming actually causes climates to get colder.
Old Jan 16, 2008 | 02:38 PM
d00df00d's Avatar
I said that already.
Old Jan 16, 2008 | 02:51 PM
VEvolution's Avatar
I miss my VE
Can't wait
Old Feb 1, 2008 | 09:23 PM
heynow's Avatar
.....you guys seem to have gotten a bit off-topic. I wanted to ask this exact question. Good thing i saw this thread.
I've used M1: EP Synthetic for the last 3 oil changes. It had 128K miles on it at the time.
The previous owner was using Castrol Synthetic blend.(the crappy one)
Since switching over to M1, i've developed a rear valve cover leak (which was fixed) and a TC cover leak that's been getting worse during the colder months.
I've been trying out Auto-RX, and i'm wrapping up my 1st rinse phase. (I was afraid of switching to Dino to do the Auto-RX)
Since Synthetic is prone to make leak problems look worse (seems like it was responsible for the leak in the 1st place); i was wondering if i can switch back to Dino oil with my next oil change and do a 2nd Auto-RX treatment.
Will it be okay to switch from Synthetic back to Dino? I've heard that it's not reccomended.
Old Feb 3, 2008 | 12:49 PM
UncleMax98's Avatar
It is okay to switch back to dino. My car actually runs quieter with dino than with Mobil-1. Are you doing the Auto RX rinse phase with Mobil-1? I thought you are supposed to use dino for rinse phase.
Old Feb 3, 2008 | 02:30 PM
heynow's Avatar
Thanks for your reply. Yes, i'm done with the cleaning phase, and finishing the rinse phase. You're right, but it turns out it doesn't matter, unless you're engine is heavily sluged-up.
Old Feb 4, 2008 | 07:49 AM
Colonel's Avatar
Old Fuddy Duddy
Dino causes seals to swell. Syn keeps them at their "normal" status. If you have a leak with syn, you have a problem that needs fixed.
Syn does not cause leaks. The reduction in seal swelling and the better cleaning properties of syn reveal (not cause) leaks. If you leak, you need a repair.
Old Feb 4, 2008 | 09:45 AM
d00df00d's Avatar
Not all dino causes seals to swell, and not all syn keeps them normal. It depends on the formulation and the seal in question.
That said, yes, the most syn will do is reveal problems that need to be fixed. It doesn't really start them per se. What I always hear is that some old engines have worn seals that are being plugged by deposits left by cheap dino oil; synthetics have superior cleaning properties and generally lower deposit formation, so they clean those deposits up and expose leaks.
I agree strongly that if such is the case, you should fix the problem no matter what oil you're using.
Old Feb 4, 2008 | 12:29 PM
Colonel's Avatar
Old Fuddy Duddy
Am I doing what I was trying not to do? Perpetuating a myth?
At least I wasnt wrong in the cleaning properties part.
Old Feb 4, 2008 | 12:50 PM
d00df00d's Avatar
You were right about some cases. I just wanted to make the caveat because there are a lot of variables involved.
Old Feb 4, 2008 | 12:59 PM
Jeff92se's Avatar
I'm needing a caw
You can switch back/forth no problems. Your engine only has 20k on it.
Old Feb 4, 2008 | 06:13 PM
Yes, it would be neglient for a major lubricant manufacturers to formulate a product that is incompatible with seals. The differing composition of seals presents problems that both petroleum oils and synthetics must overcome. As you state, ultimately it is the additive mix in oil that counts. Additives to control seal swell, shrinkage and hardening are required, whether it be a synthetic or petroleum product that is being produced.
Old Feb 10, 2008 | 11:27 PM
FishyMan's Avatar
^^ Can you elaborate or recommend me if I should stick with my AMSOIL 1 or go back dino for a few K miles? The reason is because I've just changed the valve cover and tube seals and was worried that the SYN fluid would hurt it?
Granted everything has cured and hopefully it was done right.
Old Feb 11, 2008 | 05:04 AM
d00df00d's Avatar
Synthetic oil shouldn't hurt anything. The only thing you'd want to do is to change your oil earlier than you normally would have, just to get any residue out of the system.
Old Feb 11, 2008 | 05:23 AM
Peanuthead's Avatar
Jeff, are you also saying that if you had higher mileage that you couldn't do that? I have 109K and run dino just because that was what the car had in it at 90K when I bought it.
Old Feb 18, 2008 | 10:58 PM
AF-MEDIC's Avatar
Try some maxlife in there. It has been known to recondition the seals.
Old Feb 24, 2008 | 06:40 AM
Bobo's Avatar
You should be able to convert to synthetic oil with no problems. However, given you don't know the history of the vehicle for the 1st 90k miles, I would be inclined to run AutoRX through twice before making the switch.
This will minimize the risk of developing leaks later on, while cleaning the engine internals and ring packs.
See www.auto-rx.com and www.bobistheoilguy.com
Old Feb 24, 2008 | 05:13 PM
VEvolution's Avatar
I miss my VE
Originally Posted by Bobo
OCD products ftw
Old Feb 24, 2008 | 09:03 PM
heynow's Avatar
Plus one!
JRod28
Dec 29, 2023 09:56 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
homeyclaus
Sep 3, 2015 06:15 PM
flu2000
22
Sep 2, 2015 07:29 AM
maxinout93
Aug 20, 2015 02:17 AM
