Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
SuperTech 75w/90 gear oil
Old Mar 13, 2008 | 06:34 AM
GStrength's Avatar
I been using SuperTech 75w/90 since I changed my clutch almost 10k miles ago. It feels fine, gears switch normal, however should I change it out and get with Mobil 1 75w/90 which is gl5 rated?
Old Mar 14, 2008 | 12:29 PM
nismology's Avatar
no.
Old Mar 14, 2008 | 01:35 PM
Kevlo911's Avatar
Kevlo for President
Read the stickies!
Old Mar 14, 2008 | 07:43 PM
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
What is the Wal-Mart oil rated... GL-4, or GL-5 ?
Old Mar 16, 2008 | 09:04 AM
Bobo's Avatar
Do not use GL5 gear oil! I suspect you are not using GL4, because it isn't readily available.
Locally I can get it at Mr. Lube and Pennzoil lube joints. Mr. Lube is a Canadian franchise. Try a Pennzoil location in your area if you aren't using GL4.
Old Mar 26, 2008 | 08:22 AM
mowgli29's Avatar
Horizontally opposed.
I've read the stickies as well as 8 billion opinions about gl-4 vs. gl-5.
Most people say its a freeking mortal sin if you use gear oil thats not strictly gl-4.
The Nissan dealership at which my dad works thinks otherwise...They don't carry a gl-4 specific, it's either a multigrade or just gl-5, I don't remember. My dad and the other mechanics think I'm crazy for insisting on gl-4 only. They say that the gl-5 is superior to the gl-4 (not just different, but superior...?) and by carrying what they do, they can meet the needs of people who need gl-4 and gl-5. Basically they're saying that if you need gl-4, we give you gl-5 cuz it's better. They've obviously had no adverse effects from using the gl-5...so what's the big deal?!?!
Does they FSM say GL-4 ONLY? What is written before GL-5 came out?
how do we KNOW we need GL-4 ONLY and WHY?!
Old Mar 26, 2008 | 07:16 PM
The designation of the oil (GL-4 or GL-5) has nothing to do with which lubricant is "better". It has everything to do with which oil is properly formulated for the needs of your transmission.
GL-5 oils contain significantly more EP additives than GL-4 lubes do, and those additives have been proven to affect the operation of synchronizers and to have an adverse effect on the soft metals used in fwd transaxles. GL-5 lubes are intended primarily for hypoid gears typically used in axles operating under various combinations of high speed/shock-load and low speed/high torque conditions.
Mine does. And it does not list GL-5 as an alternative.
how do we KNOW we need GL-4 ONLY ?
Because the smart people who design the components of the vehicle, those with advanced engineering degrees and a thorough understanding of metallurgy and lubricants, say we do.
and WHY?!
For the reasons I cited in the first section, above.
user 11122324
42
Jul 18, 2022 03:35 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
