Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Mixing break fluids
Old Aug 8, 2008 | 06:38 AM
myer84's Avatar
Mixing break fluids
Hi,
This morning while goind to work I noticed my break light on. Atr first I thought I still had my e-brake on, but it was all the way down. So as soon as I get to work I realized that I was a little low on break fluid so I borrowed some from a friend (DOT 3). I added and the light went off. My only concern is that I have blue break fluid that I purchased when I swapped my rottors, pads, and break lines. I think its called ATE Dot blue racing fluid. Is it bad to mix regular break fluid with the stuff I already have in the car?
Old Aug 8, 2008 | 11:51 AM
CCS2k1Max's Avatar
No, other than probably lowering the boiling point of the ATE Super Blu ever so slightly and having green fluid.
The real question is, where did the fluid in the reservoir go? Do you have a leak or are the pads worn down so much that the reservoir got low?
Old Aug 8, 2008 | 11:57 AM
mtrai760's Avatar
'Trynna' is not a word
To break to to split or bust something.
To brake is to slow or stop something.
They do not have the same meaning.
Old Aug 11, 2008 | 07:26 AM
myer84's Avatar
That is a good question. I did replace my brake line a while back since it was leaking from the area it threads on to the line that goes into the engine bay. Since then I put about 10K miles on the car, so I'm assuming brake wear has to be the reason why I had low fluid. My fluid level was near the low line since I only a little bit of fluid left when I replaced the brake line. I did inspect the drive way for any leaks, but saw nothing. I'm sure my car is not leaking, otherwise I would see it on the driveway.
Old Aug 11, 2008 | 07:27 AM
myer84's Avatar
LOL! My bad
Old Aug 15, 2008 | 06:11 AM
twiggy144's Avatar
DOT 3 DOT 4 and DOT 5.1 can be mixed, but DOT 5 can not be mixed with all others. DOT 5 is synthetic brake fluid.
D Mason
Jun 21, 2016 04:43 AM
fastcarny
Oct 12, 2015 07:06 AM
Need help
23
Oct 2, 2015 08:56 AM
Maxxx10
Sep 13, 2015 03:16 PM
