Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
quick Q about oil change
Old 05-16-2009, 02:18 PM
96max3189's Avatar
hey guys so is almost time to do my oil change since i got my engine
i got my engine whit 110,XXX now and in know im over due so what type of oil should i go for and oil filter
i was thinking of going for Royal Purple but to much money
also i was thinking of going for any kind but full synthetic but idk
what you guy thing is the best
96max3189 is offline
Old 05-16-2009, 02:26 PM
MaximamixaM's Avatar
Really any oil should be ok for 3000 miles. Probably best to invest the money on a good filter.
Any oil at walmart would be ok-even the walmart brand of Supertech. You could even go synthetic with the walmart supertech.
I used to get oil changes at garages that used Kendall oil. Probably not the "greatest", but does the job.
but as for oil, Castrol nonsynthetic or Mobil nonsynthetic or even the supertech
MaximamixaM is offline
Old 05-16-2009, 02:35 PM
AZombiePENGUIN's Avatar
i get the 75k+ synthetic with a fram filter
mobil 1
castrol
pennzoil...etc are good brands
check your autozone the people their will help
AZombiePENGUIN is offline
Old 05-16-2009, 03:52 PM
96max3189's Avatar
ok cool but wich one is batter tho full or non synthetic
Old 05-16-2009, 04:10 PM
petro2342's Avatar
There really isn't the best oil you can buy. Imo I think that it's all preference. I personally use Mobil 1 Extended Performance. Wal-Mart has it for 28.50 and use it with their oil filter for $13. Been using it since I've got my car.
You might get more responses in the right section (Fluids and Lubricants).
petro2342 is offline
Old 05-16-2009, 04:35 PM
mightyMax95's Avatar
i use the bosch filter (autozone) and castrol syntec 5w-30 (wally world).
mightyMax95 is offline
Old 05-16-2009, 05:13 PM
Product_Of_Korea's Avatar
personally i would get ams oil or mobil-1 if going the expensive route. The cheap route. i use the dyno version of the mobil with a mobil oil filter. i really give my car hell as of late and i havent had any engine problems. but then again it could just be the VQ
Product_Of_Korea is offline
Old 05-16-2009, 05:15 PM
djipka's Avatar
for the filter I only use WIX and Purolator. NAPA's filters are WIX, Supertech filter at Walmart is made by the same company as the WIX and is as good as any for a 3k oil change interval(OCI). DO NOT USE FRAM!!! They suck!
for the oil.... well that is really up to you. Pennzoil Platinum and Valvoline SynPower are the two I would use is I was doing full synthetic.
Any Pennzoil is great. Again it depends on you and what you want.
I use Valvoline MaxLife blend (red bottle) because I have unknown miles on my engine and it is a great oil for great price ($14 at Walmart fir the 5qt jug).
djipka is offline
Old 05-17-2009, 06:11 AM
Camfantasy's Avatar
no love for the oem filter anybody? i use the oem filter and the 100% synthetic amsoil.
Camfantasy is offline
Old 05-17-2009, 06:48 AM
SKOLJACK's Avatar
Castrol GTX 5W30 with a Nissan oil filter.
SKOLJACK is offline
Old 05-17-2009, 09:10 AM
max ride 41's Avatar
i use mobil with lucas oil stabilizer and it idles better and starts smoother and im at 190,650.
max ride 41 is offline
Old 05-18-2009, 03:20 AM
djipka's Avatar
^^^ Lucas is too thick for the VQ. Unless you have problems with burning oil and such DO NOT USE IT!
djipka is offline
Old 05-18-2009, 03:29 AM
Not true. I also use Lucas and as long as you use the right amount, everything is fine. With their oil stabilizer, a little goes a long way. That is the key.
ChrisMan287 is offline
Old 05-18-2009, 04:59 AM
1997 Nissan Maxima SE
Ringo1965's Avatar
I'm with djipka! I also use the Valvoline Maxlife blend transmission fluid in my car. Really when it comes down to it, use what you want just keep it changed on time!
Ringo1965 is offline
Old 05-18-2009, 08:00 AM
wxm
wxm's Avatar
OEM filter with any brand-name 5W30 (which ever on sale) on every 6month or 37K mile interval, and don't forget a new gasket for the drain plug too.
wxm is offline
Old 05-18-2009, 08:43 AM
WhiteMaxima9600's Avatar
I've had 5 vehicles 3 fords, 1 honda, and my max with 212+k miles and have used castrol gtx with fram filters in almost All of them with NO engine problems at all. I hear alot of people bashing fram but they are ok for 3-4k change intervals. That's the key to "cheap" filters. Just don't use them past 5k miles.
WhiteMaxima9600 is offline
Old 05-18-2009, 01:48 PM
deezo's Avatar
Don't use that stuff in your oil. Do the research. Additives do nothing for engine protection.
deezo is offline
Old 05-18-2009, 05:13 PM
thegontran's Avatar
Oil stabilizer is not as godd as it seem, just use a REAL syntetic oil and youll be fine!I'm using a quaker state oil filter and redline engine oil 5W30 and this is a great improvement for cold starting in winter...-25C in Quebec!...damn winter!!
thegontran is offline
Old 05-18-2009, 09:17 PM
riccohou's Avatar
i just picked up some Q horsepower full synthetic and a supertech filter. runs awesome
riccohou is offline
Old 05-23-2009, 11:54 PM
you are wrong sir, when i dont add lucas or bg the timing chain rattles louder and drives me nuts!!! the dealer recommends it for higher mileage engine's.
Old 05-26-2009, 10:49 AM
deezo's Avatar
No, I'm not wrong and I've seen this question argued until the cows came home. I've been here since 2001 and I've also seen the research over and over again.
Post anything to show me that oil additives add extra protection to any engine and I'll retract my statement.
It's been found that Lucas oil additives will make oil foamy so it's your engine, do what you want.
Lucas is not going to be your timing chain fix so go to Nissan, spend a little money and get another tensioner to fix the issue.
deezo is offline
Old 05-27-2009, 06:22 AM
vball_max's Avatar
to the OP, start reading here. Its a little outdated, but it will get you started.
http://forums.maxima.org/fluids-lubr...viscosity.html
Another great place to start reading is at www.bobistheoilguy.com. Great oil and oil filter site.
From the research I have done, if you want to run synthetic, the best oils are amsoil (expensive), mobil 1 extended performance, and pennzoil platinum. The PP seems be your best "bang for the buck" oil. If you want to run conventional, castrol GTX seems to be the front runner.
As for filters, DONT USE FRAM!!!! They are crap. I used to use those until I saw some pictures of them cut open. Now I use amsoil filters. If you buy them in bulk (case of 12) they are the same price as Mobil 1 filters at autozone and they are top of the line. PM talkinghorse or HTPerformance for pricing. Other decent options are Mobil 1 or Wix filters.
vball_max is offline
Old 05-27-2009, 02:43 PM
deezo's Avatar
Mobil 1 is fine also. I've run it since 120K miles and no problems. I'm at 267K now.
deezo is offline
Old 05-28-2009, 05:33 AM
vball_max's Avatar
Yes it is fine, however I have seen a lot of questions about it's performance lately which is why i did not include it.
Old 05-28-2009, 06:07 AM
deezo's Avatar
Linkage?
deezo is offline
Old 05-28-2009, 12:27 PM
Ad·min·is·tra·tor
DanNY's Avatar
they switched from group 4 to group 3 stock. it's still a decent oil..but i personally noticed that it burns a little more now.
DanNY is offline
Old 05-28-2009, 12:29 PM
Ad·min·is·tra·tor
DanNY's Avatar
the dealer...which is in the market to sell you more repairs recommends something doesn't mean you have to listen.
if your oil that you're using isn't strong enough to stand on it's own w/o an additive then you should change the brand of oil you're using.
DanNY is offline
Old 05-28-2009, 12:36 PM
Ad·min·is·tra·tor
DanNY's Avatar
well under "normal" circumstances the fram will do what it needs to. that's to prevent large debris from entering the engine.
- fram uses thinner walled metals in their cans
- their filtering media is recycled newspaper
- their internal valve is a cheap rubber piece or thin metal
generally the entire filter is made very cheaply and they don't really sell the filter all that cheap either.
will it filter? yup
but are you getting what you paid for? nope
if you're engine is running fine then there's no reason why the fram with castrol will cause any issues when changed within 3-4K.
but if you're running in extreme cases then the filter won't hold up too well.
DanNY is offline
Old 05-30-2009, 12:45 AM
Snypa's Avatar
Just got done chaning mine Mobil 1 synthetic 10w-30 w/ Fram tough gaurd.
Snypa is offline
Old 05-30-2009, 06:00 PM
SuPeRmOd
NismoMax80's Avatar
I just robbed Advanced Auto Parts
5 quarts of M1 EP and an M1 EP filter for $30
quarts are almost $8 each and filters almost $13
So I got 3 sets (15 quarts and 3 filter) for $90
Still going to use my Nissan filters since doing 7500 intervals while under (now extended) warranty. Will do 10-15k intervals afterward.
So changed my oil, topped off other fluids, K&N filter was stuffed filthy cleaned and recharged that. Then quick detailed her since waxed last week.
NismoMax80 is offline
Old 06-02-2009, 11:56 AM
deezo's Avatar
School these guys bruh!
deezo is offline
Old 06-12-2009, 04:26 AM
disagree, when i dont use bg or lucas, my engine taps louder. ya ya, fix the tensioner, im really trying to decide whether or not i want to do anymore to the max, 192,464 on the engine. might be getting a newer max soon. sick of dumping money into her.
Old 06-12-2009, 05:12 AM
¯\(°_o)/¯
Greeny's Avatar
you just don't get it do you? the lucas crap you're dumping in your engine is NOT helping your tensioner issue, it is only masking/hiding the problem by gumming up the works, that's what most "treatments" are designed to do.
Greeny is offline
Old 06-12-2009, 05:39 AM
Augustus Maximus's Avatar
No synthetic oil for me...
Augustus Maximus is offline
Old 06-16-2009, 12:27 PM
Ad·min·is·tra·tor
DanNY's Avatar
what oil are you using?
DanNY is offline
Old 06-16-2009, 12:28 PM
Ad·min·is·tra·tor
DanNY's Avatar
great worthless post n00b
DanNY is offline
Old 06-20-2009, 12:33 AM
SuPeRmOd
NismoMax80's Avatar
true.
i prefer good ole natural extra virgin olive oil when i cook
03-12-2020 12:06 AM
97_GXE
20
09-17-2015 08:12 PM
ag90fox
09-09-2015 12:22 PM
sdotcarter
09-02-2015 09:53 PM
maximusrising
09-02-2015 09:55 AM
Quick Reply: quick Q about oil change
