Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
First Mobil 1 5W-30 synthetic oil change
Old Jun 7, 2009 | 08:40 PM
xkazik's Avatar
Well its time to change my oil in my 1999 max i just bough and the previous owner told me he used synthetic Mobil 1 5W-30, so i decided to put same oil in, my only guest ion is what oil filter should i use ? is there special kind for synthetic oil ? and how many bottles of Mobil 1 5W-30 will i need ?
Old Jun 7, 2009 | 08:48 PM
f550maranello2's Avatar
use a nissan filter... car takes 4.25 quarts.... fixed
Old Jun 7, 2009 | 09:01 PM
mahanddeem's Avatar
4.5 quarters is much....if you're gonna replace the filter only 4 quarters are enough
Old Jun 7, 2009 | 09:23 PM
Reece616's Avatar
actually, im pretty sure the owners manual says that with an oil change and replacing the filter, that 4.25 quarts is needed...
Old Jun 7, 2009 | 09:29 PM
yea i forgot to put the 2 in front of the 5...
Old Jun 7, 2009 | 10:10 PM
haydeno's Avatar
Walmart has mobil1 5qt jugs for ~$22 and I attached a current $10 mobil1 rebate
http://uploading.com/files/Q5G4VVKQ/mobil1.pdf.html
Old Jun 7, 2009 | 10:20 PM
defiance's Avatar
Is synthetic oil really needed for the higher mileage VQ30 engines ?
I dont know alot about max's so im asking here.
Old Jun 7, 2009 | 10:32 PM
waste of money if you ask me... i stopped using it cuz it made my semi leaking rear valve cover leak like a ****...
Old Jun 7, 2009 | 11:12 PM
pmohr's Avatar
No more Maximas...
It doesn't matter.
Old Jun 8, 2009 | 12:02 AM
djipka's Avatar
Why are talking about oils and filters again? I personally have posted in many other threads with the same questions.
Old Jun 8, 2009 | 06:15 AM
xkazik's Avatar
One more question , how many miles can i put on the synthetic oil before changing it? Whats the average people change it on?
Old Jun 8, 2009 | 06:17 AM
pmohr's Avatar
No more Maximas...
Have you considered actually reading through the subforum that's designed for these questions?
They've been asked time and again, and all it takes is a little reading...
Old Jun 8, 2009 | 06:48 AM
IlyaK's Avatar
The Golden One
aka 5,000 miles.
hahaha.
Old Jun 8, 2009 | 12:06 PM
allensteiner21's Avatar
4.25 quarters is much....if you're gonna replace the filter only 4 quarters are enough
4-5/8 quarts (w/filter) per the FSM
Old Jun 8, 2009 | 12:13 PM
pmohr's Avatar
No more Maximas...
FTR, only the '95 FSM shows 4 5/8. '96-'08 show the above (well, 4.2 for '05-'08, but same thing).
'09 is up to 4 7/8 quarts, interesting.
Old Jun 9, 2009 | 07:34 AM
this is crazy. 95/9 is the same motor but the fsms have different info between years - just like the cold/hot plug use description
Old Jun 14, 2009 | 12:06 PM
JAMAICANLOVRBOY's Avatar
i seem to be the only one that cant use 5W-30 oil, or my engine will make a ticking sound until i switch to 10W-30
Old Jun 20, 2009 | 12:36 AM
NismoMax80's Avatar
SuPeRmOd
depends. my manual states 4.25 as well.
BUT i always require 4.5 to get it to the full line on the dipstick.
I even fill the filter and let it soak in. you'll be surprised how much you can fit in it.
Old Jun 20, 2009 | 12:38 AM
NismoMax80's Avatar
SuPeRmOd
you understand this is because the synthetic cleans away the crud that hid your leak right?
synthetic isn't the problem, it simply showed you the problem.
Old Jul 2, 2009 | 06:39 PM
A33Black's Avatar
I just dump in 4.0q each time I change the oil & filter. This fills it to between 3/4 and Full on the dipstick.
As a side note, FWIW, I've had a 10W-30 fill of Pennz Plat Syn w/ M1-110 filter since 12/2007. It now has only ~3000 miles on the oil. This car has been mostly in storage. This is why I haven't changed it out yet. Will probably change it out at 2 years.
So far 19+ months...oh the humanity!
Sleeping very well at night, and the sun will still rise w/ that old oil in there..
Old Jul 9, 2009 | 10:39 AM
MaxLoverAz's Avatar
Thank god for rust inhibitors...
Old Jul 11, 2009 | 12:09 PM
Col Ronson's Avatar
Don't use a nissan OEM filter. That's just a Fram in disguise. I've seen many teardowns online just go to google and type in Mobil 1 vs Nissan OEM filter teardown. If you use mobil 1 oil, use mobil 1 oil filters too.
Old Jul 14, 2009 | 09:07 AM
Colonel's Avatar
Old Fuddy Duddy
No, use Mobil1 filters because its a better filter. Not just because you are using Mobil1 oil. They are mutually exclusive and are not tied to each other.
It is nice that several auto supply places around here bundle Syn Oils with Mobil1 filters like Penz, Mobil1 and Castrol. Couple bucks off per quart and a "free" filter.
Old Jul 30, 2009 | 09:32 PM
eluther3's Avatar
Another vote for the mobil 1 filter. I started buying them because they have the check valve that keeps the oil from draining after you turnoff the engine. Thjis ensure oil will be in the engine at start.
I've been told the Mobil 1 is specially designed for synthetic oils, but I don't know if that's just manufacturer's hype.
Old Jul 30, 2009 | 09:33 PM
eluther3's Avatar
p.s. regarding oil change interval - I shoot for 5K on each oil change, but usually I look at the oil around that time and if it's not dirty, I might drive another 1-2K on it.
Old Aug 1, 2009 | 07:24 PM
Col Ronson's Avatar
well you can use it with any oil you want. i use it because although expensive, its the best filter out there, although the amsoil drones will argue theirs is better. it has synthetic filter material instead of plain paper, so supposedly there are smaller fibers that allow for more filtering area. so less sludge floating around your engine. i immediately saw a difference in the oil drains from my dyno drain to my syn drain 4000 miles later.
Old Aug 5, 2009 | 10:16 AM
Colonel's Avatar
Old Fuddy Duddy
Oh, what was it that you visually noted?
Old Aug 7, 2009 | 08:23 PM
dandjjohnson's Avatar
For both my 95 and 2001 Maximas, I simply poured an entire jug of Mobil 1 synthetic in (5 qts). I know they took a little less according to the manuals, but a little extra oil never caused a problem...
Old Aug 7, 2009 | 08:24 PM
Ohhh, and any filter other than FRAM seems to work fine...
JoshG
51
Sep 21, 2015 10:41 PM
97_GXE
20
Sep 17, 2015 08:12 PM
pjgreek
Sep 9, 2015 09:30 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
