Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
View Poll Results: Choice of oil?
Mobil 1
58
41.13%
Valvoline
7.80%
Royal Purple
7.80%
Redline
0%
Pennzoil
9.22%
OTHER
48
34.04%
Voters: 141. You may not vote on this poll
YOUR CHOICE IN MOTOR OIL
Old Sep 13, 2009 | 11:46 AM
  #81
Crusher103's Avatar
mobil 1 5W-30 and their filter or a purolator and call it a day, im not about to pay over $30 for an oil change, i dont think royal purple is worth it when mobil 1 is comparably as good and is cheaper
Old Sep 13, 2009 | 03:44 PM
  #82
Leo_Koneval's Avatar
Haha probably, I guess I am just too picky when it comes to this stuff. I used to pay $35 for some "services" at Grease Monkey just for them to fill up my car with some cruddy generic brand of oil that they won't give me details on because it is a company "secret"
And I think them vacuuming my car and cleaning the windows doesn't justify the price, either
But yeah I think I will just buy some M1 oil and filter and change it out and call it a day. All this debate is confusing.
Old Sep 14, 2009 | 05:00 PM
  #83
Christobal65's Avatar
I really recommend the Rotella T (either 15W-40 or Syn 5W-40) Cheaper than Mobil 1 and arguably its a superior oil.
Old Sep 15, 2009 | 01:44 PM
  #84
Actually you have a point it seems like Rotella T is AS good or BETTER than Mobile1 from what I have seen in some Google searches
And Wal-Mart carries that brand of oil too, YAY!
Old Sep 15, 2009 | 01:49 PM
  #85
Jeff92se's Avatar
I'm needing a caw
I wish Rotella made a 30w. If you guys want to run it, I suggest the 5W synthetic. A 15 winter viscosity is probably too think especially with winter coming up.
Old Sep 15, 2009 | 03:04 PM
  #86
This is a little out there but it seems like there is a Maxima racing brand oil? Sorry didn't do much research on this, but it seems like there is a oil made specifically for Maximas, I think...
http://www.maximausa.com/products/4s...xum4ultra5.asp
Old Sep 15, 2009 | 06:04 PM
  #87
It depends on where you live, how cold it gets, and if you park your car outside, but yes the 5w-40 is a better idea in a cold climate
Old Sep 16, 2009 | 09:18 AM
  #88
Jeff92se's Avatar
I'm needing a caw
15w weight is pretty thick anywhere in the country actually and there's no real reason to use it when there's a 5w available (that's actually within the oem recommended viscosity range). At startup, you want the oil up in the valvetrain asap.
Old Sep 16, 2009 | 11:57 AM
  #89
Yes but the FSM (for my 01) says that 5w-30 is preferred for temps from -20 to 100 degrees, and 10w-30/40 is fine if temps dont go below 0 degrees. Now while it doesn't say anything about oil with a thicker cold weight you would be fine with a 15w-40 in temps over 32 degrees...
Now that being said i recommend the 5W-40 synthetic.
Old Sep 16, 2009 | 12:02 PM
  #90
Jeff92se's Avatar
I'm needing a caw
I'll have to respectfully disagree here. The FSM doesn't say you can't run 100w either but I think that would be a bad idea.
In the end, 15w would "probably" be okay as long as not that cold as you say. But with winter coming up, 32 deg is easy to get as soon as Oct. But again, why ice skate uphill when there's a 5w 40 made by the same brand? (Rotella)
Old Sep 16, 2009 | 12:08 PM
  #91
I agree but I live in a part of the country where temps below 32 degrees are rather rare
Old Sep 16, 2009 | 05:52 PM
  #92
Wow Shell Rotella is popular in my area, I went to Wal-Mart and ALL of the 5W weight is gone, and the Delo 400 was sold out, then I went to two different auto stores near my house and its all sold out!
The only things left were Quaker State and Pennzoil and Mobile1... darn...
Oh and I am not sure if its true but I asked the guy at the auto store if he had any 0W and he said that 0W is bad because its too runny and won't lubricate adequately until its warmer.
Old Sep 16, 2009 | 06:10 PM
  #93
Theres nothing really wrong with running a 0w oil but most guys who run their cars hard (ie road courses etc) dont like it since the amount of VII (Viscosity Index Improver) is pretty high. Once VII's are 'used up' they are gone and the oil is always a lower weight oil.
Old Sep 18, 2009 | 11:17 AM
  #94
Haha after seeing all those Delo 400 and Shell Rotella oils eaten up, I think I am a believer. You can tell what oil is good and whats bad by whats left on the shelves and whats sold out haha
Old Sep 18, 2009 | 12:10 PM
  #95
I was over at the Subaru forums and it seems like Shell Rotella has lots of Zinc and stuff that is bad for the catalytic converter if your car is consuming oil. Not sure if it applies to Maximas since its a different engine and all but consuming oil...is consuming oil so, just another thing to think about.
But my car is fine as it doesn't consume oil so I am going to surely switch over to Rotella.
Old Sep 18, 2009 | 02:12 PM
  #96
Yeah thats part of what makes it so great for protection. It isnt the best for cats, but its not going to kill them either.
Old Sep 18, 2009 | 04:48 PM
  #97
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
You're right, high amounts of Zinc has been found to be harmful to catalytic converters, and your engine does not have to be consuming great amounts of oil for it to have an adverse effect. Diesel oils typically contain a more aggressive additive package to combat the effects of diesel combustion. High amounts of zinc in an oil won't kill the catalytic converter immediately, but it will affect it over time. And that's why the API significantly reduced the amount of Zinc that can be included in oils rated SM.
Old Sep 18, 2009 | 05:31 PM
  #98
DAVE Sz's Avatar
Hooooooonda.....
Noticed the same at the walmarts and stores around here except the problem was they don't restock those oils as often as the other ones simply cause they don't sell as well. The same 4 bottles of rotella have been sitting at the closest walmart for almost 2 weeks now and they won't restock til 2 are left. Sucks cause they are out of the 5w and won't restock til the 15w are down to two. Don't know why...
Old Sep 30, 2009 | 09:55 AM
  #99
w8lifter21's Avatar
K&N filter and Eneos oil. I get pretty good prices from my suppliers
Old Sep 30, 2009 | 11:57 PM
  #100
Odd haha, but I just noticed that you can get Rotella T at any Shell gas station, the station near me, has all the weights in full stock!!!
I would have never expected to go to a gas station for my oil but it seems like that is the best place to get Rotella T if Wal-Mart is out.
Old Oct 1, 2009 | 02:20 PM
  #101
Col Ronson's Avatar
gas stations will charge you more than anywhere else. Why? they know anyone who buys oil at a gas station probably needs it in a hurry so they'll charge a premium for it and take advantage of destitute drivers. I know autozone has Rotella too.
Old Oct 1, 2009 | 09:33 PM
  #102
Aww
I didn't look at the price I was actually just buying gas when I spotted in the corner of my eye a shelf full of jugs and I glanced and "HEY! rotella t in 5W-30"
But yeah you are probably right, knowing how everything in gas stations are more expensive, especially food. I mean 4 dollars for a hot dog!!!!! This is an outrage!
Old Oct 2, 2009 | 09:44 PM
  #103
STILLENGLE's Avatar
May I ask why you guys are Running Roletta T 15w-40 or whatever it is for diesels? your gonna burn your cats out doing that. the only reason why subaru guys do it is because its good for the turbo, but even them have a risk of buring their cats out.
On a sidenote, I just looked at the link for the oil analysis from my350z, and I saw no oil recommendations on there. I just did an oil change, I used Castrol GTX 5w-30 with a Mobil 1 M1-110 filter.
Old Oct 2, 2009 | 10:26 PM
  #104
Not entirely true. Zinc is hard on cats but its only in the last 5 or so years that zinc levels in 'automotive oil' have come down. What will happen is your cats will loose effectiveness ever so slowly...but they do that anyways. Its not that its just 'good for the turbo,' its that the oil is good against shear and offers superior wear protection to 'automotive oil.'
Old Oct 3, 2009 | 12:24 AM
  #105
Yup apparently the things in the oil that makes it bad for our cats is exactly what makes it such a good oil, and good at protecting your engine.
I don't know how it compares to Mobil1 and Castrol, but for Rotella's price and what it has been said to do, I think that it is worth its weight in gold
Old Oct 10, 2009 | 08:01 PM
  #106
NIKV69's Avatar
Proudly just switched to Amsoil sig 0W30! Kept the Nissan Filter (the good one)
Old Oct 14, 2009 | 05:09 PM
  #107
Bobo's Avatar
I live in British Columbia and run Esso Extra XD3 0w-30 full synthetic and a Napa Gold filter. I don't believe this oil is available in the US, at least it wasn't a year or two ago.
I haven't been on this forum or BITOG much lately. When I started using it, it was raved about on BITOG. It is a diesel application. What attracted me to it was the fact that it consistently outperformed Mobil 1 on UOAs and is only about 2/3s the price.
It is only available in Canada at Esso bulk plants.
My car is a 95SE, 5-speed, with 79,850 mostly highway miles.
Old Oct 14, 2009 | 10:49 PM
  #108
MorpheusZero's Avatar
OT: Holy crap, you're back? I haven't seen anything from you in years.
Old Oct 15, 2009 | 08:22 AM
  #109
Bobo's Avatar
I'm on periodically, but not posting that much.
I just had my tranny rebuilt 2 months ago as a result of the dreaded differential carrier bearing problem. All bearings and seals replaced. New clutch kit as well while the tranny was out, despite the fact it was good to go for a few more years.
Old Oct 16, 2009 | 03:55 PM
  #110
a33i30's Avatar
Royal Purple with K&N filter
Old Oct 20, 2009 | 03:33 PM
  #111
Jeff92se's Avatar
I'm needing a caw
Rotella T is reducing the amount of zinc now. But the anti-wear properties of zinc wasn't the only good reason to use this oil. It has a very robust additive package also.
http://www.fordmuscle.com/forums/gar...-oil-gone.html
Old Oct 20, 2009 | 03:58 PM
  #112
Jeff92se's Avatar
I'm needing a caw
Rotella T5 is a synthetic blend that's available in a 10w 30. Their top of the line full synthetic T6 is available in a 5w 40.
Old Oct 25, 2009 | 04:27 PM
  #113
CraigSE's Avatar
On a VQ series in my family, always German Castrol 0w30 and Wix filters.
Old Oct 25, 2009 | 09:41 PM
  #114
MaxEx's Avatar
Pennzoil Platinum and Pure One filter every 7.5k. You can't go wrong with that.
Old Oct 26, 2009 | 09:06 PM
  #115
Sentinal's Avatar
+1. With some filter mags
Old Oct 27, 2009 | 01:05 PM
  #116
krazy6's Avatar
I use either mobil 1 or castrol syntech.
Also, mobil 1 or K&N oil filters.
Old Oct 31, 2009 | 07:12 AM
  #117
crug75hid's Avatar
Shell Rotella and Castrol Syntech both are excellent in Lubricant oils as the quality of the oils are very good and I hope these lubricants will increase the engine too.
Old Nov 9, 2009 | 11:04 AM
  #118
jason3361's Avatar
switched around a couple of time and never had a problem with my engine... I just make sure I change my oil and filter every three months no matter the milege. Buy it when on sale so it's realy only my time that add up.
spencerwh1
Jun 30, 2016 05:44 AM
fastcarny
Oct 12, 2015 07:06 AM
foodmanry
Sep 24, 2015 12:02 PM
RWCreative
Sep 21, 2015 11:01 AM
ag90fox
Sep 9, 2015 12:22 PM
