Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Marine TC-W3 two stroke oil as a gasoline additive - NEW
Old Aug 29, 2017 | 06:14 PM
  #121
Amerikaner83's Avatar
Nice to know this thread is still alive and helpful
Old Oct 18, 2018 | 06:11 PM
  #122
98maxBK's Avatar
Just started the tc-w3 treatment on my 98 max se. Hope it cleans the $&@k out of my injectors. Been getting a sporadic bucking almost like a miss in drive/ reverse at stop. Swapped all coils and changed plugs to no avail. Cleaned tb/ iac etc. fingers crossed with the treatment
fyi did some sea foam then a couple tanks with chevron Techron and the bucking happens much less frequent so I think problem is fuel related. Also changed fuel filter recently.
Old Oct 18, 2018 | 08:16 PM
  #123
londonflu's Avatar
Sounds like a bad injector, disconnect the plug from the coils one at a time to find which one it is, what you're looking for is no change in idle, that's the bad injector.
Old Oct 19, 2018 | 05:59 AM
  #124
Run TCW3 in my turbo car
Old Oct 19, 2018 | 07:51 AM
  #125
98maxBK's Avatar
Tried that before I swapped coils. Idle bogs down on every cylinder when coil is unplugged.
Old Nov 26, 2018 | 10:42 AM
  #126
PH98I30's Avatar
I run TC-W3 in all my cars. No injector problems, no idle problems and no smog check problems. Been running it in my cars for 7 years now. This stuff is bomdiggity!
Old Dec 4, 2018 | 09:00 AM
  #127
Prophecy99's Avatar
i am enjoying as well for at least 6 years
Old May 8, 2019 | 01:53 PM
  #128
mikeg75's Avatar
Is there a shelf life to TCW-3? I haven't put it in my car for a few years now and recently the P0400 code started coming up, so I am going to do two things:
- replace the gas cap
- refill with premium and add TCW-3
Can I use the TCW-3 that has been sitting in my garage for 2+ years?
Old May 8, 2019 | 03:04 PM
  #129
BobPezz's Avatar
It looks like there's no shelf life according to this link. https://forums.iboats.com/forum/engi...-w3-shelf-life
Old May 9, 2019 | 04:35 AM
  #130
Turbobink's Avatar
...but an EGR no/low flow DTC doesn't have anything to do with a gas cap or with fuel grade.
Old May 10, 2019 | 06:33 PM
  #131
mikeg75's Avatar
After the new fuel and fuel cap replacement, letting it run 30 min and driving around the past couple days, the EGR code hasn't come back but I'll post if it does.
Thanks for the ideas, guys.
Old May 21, 2019 | 12:25 PM
  #132
Prophecy99's Avatar
still using this on my 5.5 gen, been 6-7 years. i also luckly have a ethanol free gas station near my work for my small engines (mowers , yard equipment)
i also saw a wawa gas station in the Poconos with an ethanal free 87 octane. pretty cool!
Old Sep 27, 2019 | 07:25 AM
  #133
Jbkflowers's Avatar
Tried TC-W3 for first time last night at a fill up on 5th gen with 225042 miles. Was my moms car and recently inherited it. Notice a difference already in smoothness at idle and quietness. I’m a believer!!
Old Sep 30, 2019 | 07:45 AM
  #134
Prophecy99's Avatar
takes 3 tanks to start the benefits
xorbitman
Dec 8, 2013 01:26 PM
worldwiderecognized
Aug 23, 2011 10:45 AM
Br0nz
Jun 23, 2010 08:16 AM
renatonetmail
Mar 15, 2005 01:18 PM
Evil_Twin
May 17, 2004 12:37 PM
