Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
98 radiator flush/fluid change
Old Apr 30, 2019 | 09:56 AM
malaysteve's Avatar
Hello, I am going to be changing out my wifes granddaughters 1998 maxima antifreeze. Going to drain the radiator and flush it out with distilled water,etc. I am not going to be touching the block drain plugs. My question is after I am done and ready to refill the radiator and reservoir, do I put in straight antifreeze, or do I put in 50/50. I would think 50/50 in reservoir, but unsure about radiator since there will be some water in it from the block. Thanks for the replys.
Old May 1, 2019 | 05:14 AM
Turbobink's Avatar
What's the owner's manual say?
Old May 1, 2019 | 07:40 AM
malaysteve's Avatar
Just purchased the car, did not have owners manual.
Old May 1, 2019 | 08:23 AM
Turbobink's Avatar
The overall ratio of coolant to H2O should be no greater than 50:50.
If you know the total coolant system capacity you can add H2O then add coolant so that a 50:50 mix is the result.
Aside from that, using a premixed 50:50 product is acceptable.
Old May 3, 2019 | 04:35 PM
mahanddeem's Avatar
That's what exactly the op asked about.
Long gone the days when people used to read!
Erin_Maxi
May 19, 2013 08:10 AM
xiton
May 15, 2012 01:45 PM
B.C.
Oct 4, 2011 07:14 PM
Neeferea
Jul 9, 2004 04:05 PM
Stringman8
Nov 10, 2003 12:15 AM
