Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Oil Changing question
Old Feb 10, 2002 | 11:52 AM
Matticus's Avatar
My oil filter wrench turned out to be too small to fit on the Nissan oil filter, so I put clean oil back into the engine. My question is, do you have to drain the oil in order to change the filter? Or when I get the right size wrench can I just unscrew the filter and put on the new one?
Thanks.
Old Feb 10, 2002 | 11:56 AM
iwannabmw's Avatar
Re: Oil Changing question
Thanks.
You can change the filter without changing the oil. You will lose the same amount that the filter can hold, so you'll end up being 1/2 quart low. If the wrench doesn't fit, you can use an old belt (for pants) and wrap it around the filter in a way that when you pull on it, it will twist the filter the right way. This is kind of hard to explain without a picture, but if you look at the filter you can probably figure it out.
Old Feb 10, 2002 | 11:59 AM
Matticus's Avatar
Re: Re: Oil Changing question
Cool, thankz for the answer and the idea.
Old Feb 10, 2002 | 05:01 PM
slider71's Avatar
Re: Re: Re: Oil Changing question
Wait a sec...you talking about unscrewing the filter without draining the oil? Yes, you can re-use the filter (ie change just the oil...not good, but okay if a must)....but you absolutely cannot cannot change the filter in isolation without loosing ALL of your undrained oil.
Old Feb 10, 2002 | 05:36 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Re: Re: Re: Re: Oil Changing question
I disagree.. you will lose some but not ALL. There might be some confusion, he is talking about taking off the filter and then putting a new one on.
I do not think he would lose more than a quart.
Old Feb 10, 2002 | 08:29 PM
theMax's Avatar
Re: Re: Re: Re: Re: Oil Changing question
nice sig, what is that a f16?
Old Feb 10, 2002 | 09:00 PM
punkdork's Avatar
Most engines have the filter near the bottom. Remove that and it's like taking the drain plug out. It'll be a nasty mess. I'd wait on the filter untill next time around.
Old Feb 11, 2002 | 07:20 AM
iwannabmw's Avatar
Yes, the filter is near the bottom, but it is above the oil pan by a little. After the engine has been off for a little while and the oil has all drained down to the pan, the only oil you will lose is what comes out with the filter.
Old Feb 12, 2002 | 03:58 AM
wdave's Avatar
Re: Re: Re: Re: Re: Re: Oil Changing question
The filter is on the block, the oil is in the pan, the pan is below the block.
Old Feb 12, 2002 | 08:34 AM
srbarnes4ever's Avatar
Just changed mine for the 3rd time (16K miles) this past weekend...I always remove the oil filter first to clean off that area and replace the filter then remove the drain plug. You definitely only lose what's in the filter and no more...its higher than the standing oil in the pan assuming you let it sit a minute or two for gravity to do its thing.
2k1seae's Avatar
Several years ago when I first went to synthetic oil in my 91 Max, an auto tech recommended that the oil be changed about once a year, but to change the filter about every 3000 - 4000 miles. I did this and only lost the oil that was in the filter (app 1/2 to 1 quart)when I changed the filter. Then I topped off the oil. I don't think you will lose all of your oil. IMO
Old Feb 12, 2002 | 09:15 AM
djmaxski's Avatar
Yep, the filters are the weak link in using synthetic oils
Old Feb 12, 2002 | 09:27 AM
zeitgeist57's Avatar
Change filter...but not the oil?!?!
Interesting idea! But it makes perfect sense, since syn oil lasts longer than dyno oil. Not to mention it's resistance to temperature and moisture...the two biggest contributors to dyno oil breakdown. As long as you have a good quality CLEAN oil filter on your Max, I can see that syn oil would last safely through the lifespans of two oil filters
What filter does everybody use? I have Mobil 1 and a FRAM (yuck) filter on my 2k1, but JUST because that's the only filter available for my Max at the store at that time. Any recommended filters?
Old Feb 12, 2002 | 09:38 AM
Re: Change filter...but not the oil?!?!
I use Amsoil currently but Mobil One's synthetic fiber version is just as good and available locally in auto parts stores... I plan to go 5 to 6K per filter change and change the oil every 2nd filter change until I get some oil analysis data supporting anything different on my vehicle...Unfortunately in my haste this weekend I forgot to bring out the Blackstone vial when I did my change.
Old Feb 16, 2002 | 05:54 PM
ceazer458
Oil changing question
You will lose about a 1/2 a quart I agree. I have been changing my oil for over 6 yrs you won't have a problem. The belt idea works!!!!!
kmitchel
Oct 30, 2016 05:28 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
Johnny9595
Sep 3, 2015 05:18 AM
tnewbs
Aug 28, 2015 10:15 AM
maxinout93
Aug 20, 2015 02:17 AM
