Forced Induction Sell your turbos, supercharger, nitrous, and related items here
CT 96 jwt boosted ecu
Old Oct 1, 2012 | 03:38 PM
TurboA32's Avatar
96 jwt boosted ecu
Up for sale is a 96 jwt ecu 5speed. It's programmed for nismo 555cc Injectors, z32 maf, boosted program, 9:1 cr. Price is $450 shipped in the USA. This is a plug n play modd on a 96 with no check engine light but will work on other years if you know what your doing. Serious buyers only thanks
Old Oct 1, 2012 | 04:33 PM
TurboA32's Avatar
Old Oct 1, 2012 | 04:51 PM
t6378tp's Avatar
Turbo 3.5
auto or 5spd
Also what timing
Old Oct 2, 2012 | 03:28 PM
kasso28's Avatar
damn why does this have to be available when I have no money.... lol its programmed for my exact goal... GLWS
Old Oct 2, 2012 | 05:49 PM
Max streets's Avatar
can it be for a 3.5 swap auto
Old Oct 2, 2012 | 09:43 PM
95naSTA's Avatar
What rev limit and x2 on what timing?
Old Oct 3, 2012 | 07:33 AM
TurboA32's Avatar
As long as your using a 4th gen engine harness it will work and as long as you know what your doing
Old Oct 3, 2012 | 07:40 AM
TurboA32's Avatar
7200 rpm and as far as timing its programed for boost so Idk i know that i have 3.0 timing if that helps your timing question
Old Oct 3, 2012 | 07:43 AM
TurboA32's Avatar
Originally Posted by t6378tp
auto or 5spd
Also what timing
5spd and i made a comment about the timing in the post above
Old Oct 3, 2012 | 10:52 AM
95naSTA's Avatar
For the timing, I'm more specifically trying to see if the ignition timing was advanced or retarded and how far. I'm assuming retarded but wanted to be sure.
Old Oct 3, 2012 | 01:50 PM
t6378tp's Avatar
Turbo 3.5
same here trying to see if the timing is set to 10, 16 or 18 degrees
Old Oct 3, 2012 | 05:41 PM
TurboA32's Avatar
Most likely its retarded because its programed for boost
Old Oct 3, 2012 | 06:30 PM
t6378tp's Avatar
Turbo 3.5
we know it's retarded but how much
Old Oct 3, 2012 | 10:55 PM
TurboA32's Avatar
I don't know I would have to hook it up to my tool but my car is gutted so that's a no go I'll just call Ben at Jim wolf technology and ask him
Old Oct 4, 2012 | 03:35 PM
TurboA32's Avatar
Just talked to Ben at Jim wolf technology and he said the timing is stock that you can't change it so you don't have to worry about the timing because it is programmed for boost and if you have any questions give him a call
Old Oct 5, 2012 | 08:03 AM
chongher's Avatar
Is it fed spec or cali spec?
Old Oct 5, 2012 | 08:52 AM
TurboA32's Avatar
It comes up as a cali spec but i think 95 and 96 ecu cali and fed are the same because they still have 3 wire o2 sensors three of them
Old Oct 7, 2012 | 05:34 PM
TurboA32's Avatar
Note this is a plug n play modd for people that don't really want to tune their car. Just get in and drive
Old Oct 13, 2012 | 01:34 PM
hvyft's Avatar
i've tried searching, but will this work with a 97 (07/96 manufacturer date if that makes a difference)?
if it does, i know its tuned for 555's, will it cause problems with 370cc injectors? Would it be better than running a TS ecu tuned for a32 MAF and stock injectors?
Old Oct 14, 2012 | 10:42 AM
t6378tp's Avatar
Turbo 3.5
Yes it will work on a 97 and if you use smaller injectors it will run lean
Old Oct 14, 2012 | 08:48 PM
TurboA32's Avatar
It will work in a 97 but you might have a cel but it won't effect your performance. And the 370cc on this ecu is a no go. It won't run right its programmed for the nismo 555cc Injectors which flow about 608-615 cc according to Ben at Jim wolf. as you see it says 608cc on the ecu
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
gigabyte
Jan 6, 2017 06:05 PM
MichMaxFan
Sep 30, 2015 09:18 AM
