Forced Induction Sell your turbos, supercharger, nitrous, and related items here
AL wiseco 11.1
Old Feb 18, 2013 | 12:15 PM
YANvq35's Avatar
wiseco 11.1
http://www.ebay.com/itm/VQ35-VQ35DE-...beb3a1&vxp=mtr
Old Feb 18, 2013 | 03:21 PM
kasso28's Avatar
Not hating, but those arent FI pistons... glws though
Old Feb 23, 2013 | 07:35 AM
Max streets's Avatar
duh .it cant be run with turbo but it can take a supercharger and that compression is na or supercharger.
Old Feb 27, 2013 | 08:24 PM
kasso28's Avatar
I dont know where you learned about cars bro, but boost is boost whether is a supercharger or turbocharger...
This ad is in the wrong section cause someone can possibly blow their engine using these pistons for forced induction.
Old Mar 14, 2013 | 06:45 AM
VQtHuRtY's Avatar
These are for all motor setups(high compression pistons).
Old Mar 15, 2013 | 11:18 PM
um their g35 and 350z with high compresion running superchargers due to the boost comes in later than a turbo.
Old Mar 19, 2013 | 08:31 AM
VQtHuRtY's Avatar
Hope you're joking... Since when does the supercharger "boost" kick in later than a turbo? And even then, they should be running low compression for better engine efficiency. I guess its one of those things: "it can be done, the question is should it"
Old Mar 20, 2013 | 03:40 AM
As of rit now GTM is making a new SC kit for the vq35 de Z platform puting it on a 4.2 stroker with an 11 compresion but they dont recomend any higher than that.thier also someone else that just made 634hp on a vortech v2 with that compression.
Old Mar 22, 2013 | 12:21 PM
aic96max's Avatar
OMG: you can boost any compression motor , these should work fine just cant swallow as much air as lower compression. still make the power, just will take less boost if you think about it,less than a lower compression motor (aside from tuning and octane levels )
Old Mar 23, 2013 | 08:23 AM
t6378tp's Avatar
Turbo 3.5
I was going to run 11.1cr on my g35 superchargered, overall hp would have been the same with less boost but I would have had more tq and power under the curve
I wouldn't run these with a turbo less your staying under 10psi
Old Mar 23, 2013 | 06:47 PM
kasso28's Avatar
makes sense, but not many people understand tuning, and these pistons are more prone to detonation. Plus, seems stupid to spend money/time building a motor to run less boost than the stock motor...
zyirock
Dec 9, 2015 10:22 PM
Kgkeen101
Dec 12, 2012 10:45 AM
Kgkeen101
Dec 12, 2012 06:16 AM
Kgkeen101
Nov 19, 2012 04:37 PM
MardiGrasMax
Sep 14, 2004 07:00 PM
