Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
Angle Wrench - For Angular Tightening Method
Old Dec 1, 2008 | 07:25 PM
1993-VG30E-GXE's Avatar
What is the FSM talking about in the Mechanical section, this angle wrench? I've never seen one of these for sale before. Used I think for the cylinder head bolts.
It says "some bolts need to use the angular tightening method as opposed to torque wrench method".
Old Dec 2, 2008 | 07:14 AM
Greeny's Avatar
¯\(°_o)/¯
http://maxima.theowensfamily.com/tsb/NTB90-090.pdf
The only 2 bolts nissan "requires" angular tightening are cylinder head bolts, and connection rod cap nuts.
Updated torque/angular wrench:
http://buy1.snapon.com/catalog/item....store&tool=all
Old Dec 15, 2008 | 11:00 PM
Greeny I picked up the old fashioned kind...the exact one in the Tech Bulletin PDF you posted (Snap On one on right)
What's the point of the arm thing. How do I use it? Didn't come with a manual.
Old Dec 16, 2008 | 03:04 AM
Greeny's Avatar
¯\(°_o)/¯
I have no clue dude, I've never used one.
Old Dec 16, 2008 | 03:19 AM
SEmy2K2go's Avatar
Go BUCKS!!!
TORQUE ANGLE METER
* Measures angle of rotation after pre-torque load in "torque-angle" applications
* Includes 1/2" male and female square drives for both sockets and wrenches
* Measures in 5-degree increments on large easy-to-read dial
Those bolts are done in two stages; a pre load and a final torque value which is done by turning the bold a specific degree. Some head bolts are done in this manner so it is not an old or weird way of doing it. I also beleive the bolts are to be oiled prior in installing, check the manual.
1- pre load the bolt as specd in the manual.
2- put your wrench on the bolt.
3- use a protractor and mark 32' on the case from the wrench.
4- turn your wrench to the mark.
5- done!
One word of warning, when angle tightining do it in one fluid motion. You only get one shot with these bolts, it's not really that big of a deal to do it right.
http://www.advrider.com/forums/showp...2&postcount=12
Old Dec 16, 2008 | 07:00 PM
Thanks guys - and the pics are great. I get it now - you just stick the arm thing against something, and the dial rotates. At first I thought you had to hold it while using the wrench with the other hand - then I figured this would be impossible to do it in one motion.
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
thenewguyy
Sep 12, 2015 11:12 AM
