Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
Fastest Small Cut Off Wheel For Die Grinder
Old Apr 11, 2009 | 11:24 AM
1993-VG30E-GXE's Avatar
I've been using a 2" Walter Zip wheel to cut off M14 Hex Nuts & Bolt, at approx 22,000 RPM. The material of the wheel is some sort of fibre or kevlar. Does anyone know of a better wheel that can cut faster? This wheel takes horribly long. What about the metal wheels, I think called Diamond Cut Off Wheel.
Old Apr 11, 2009 | 02:17 PM
VQP0WER's Avatar
That's a tiny wheel. Get a 4" wheel and a angle grinder. Use a wheel specifically made for the material being cut.
http://www.pferdusa.com/products/206/20602/index.html
Old Apr 14, 2009 | 07:40 PM
Matt93SE's Avatar
STFU n00b!
M14?
you need a torch, not a wheel.
Old Apr 14, 2009 | 09:03 PM
I was wondering that. It was taking way too long. I take it then you are refering to a plasma cutter. Too bad I couldn't rent one. Anyways, to speed it up as much as I could, I actually used an old fashioned hacksaw, and it went much faster. Those end bolts were actually positioned so you could fit the hand saw.
I did get through them, but I was actually cutting through the diameter of the M14 Hex hut & the rod through it, so it with pretty thick...the die grinder did about 80% of the work - I had to cut it right at the washer, and in fact it ground down 1/4 of the washer, just to make sure I didn't finish cutting and there were these left over bits that wouldn't let the bolt slide out through the strut.
sctludwig
Sep 1, 2022 01:32 PM
2kmaximel
Sep 10, 2015 08:13 AM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
