Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
Engine hoist leveler
Old Aug 2, 2009 | 12:27 PM
96sleepergle's Avatar
Has anyone used the leveler on an engine hoist to remove the entire engine and transmission together by shifting the weight in one direction i so please provide some info, i have an engine hoist with a leveler want to put it to good use for time saving of the entire process thanks!
Old Aug 5, 2009 | 09:56 PM
1993-VG30E-GXE's Avatar
Maybe post this in your gen forum. With the VG, it looked to close for comfort.
Old Aug 5, 2009 | 10:00 PM
SEmy2K2go's Avatar
Go BUCKS!!!
What info are you specifically looking for?
Old Aug 5, 2009 | 11:34 PM
first post clearly stated
Clearance issue wise?
Old Aug 6, 2009 | 12:01 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Not really clear actually.
Yes, I'm sure people have used them (as have I). Do you just want to know who else has used one before? They do work pretty well.
Old Aug 6, 2009 | 11:39 AM
The issue with the VG is that the side cover of the tranny looks like it'll smack the part of the engine bay above it, when trying to lift it out, then if moving it in the opposite direction, I may smack the pulleys against that other side of the engine bay.
I'll take some pics today, i'm removing my engine with the leveler and removing the tranny from below. You'll see what I mean how close it is.
Old Aug 7, 2009 | 02:06 AM
Read my post buddy in the 3rd gen forum when I post pictures tommorow of the hoist that failed on me.
I'm getting my money back and going with a different brand.
Old Aug 7, 2009 | 08:45 AM
Ok but is was basiclly stating with the leveler you can shift the weight of the motor and transmission and pull it out all together instead of taking the trans off first its a 4 gen 5speed, i just did a dek swap was goingto rebuild the de motor then swap it back
Old Aug 7, 2009 | 08:46 AM
ok kool, that crazy that a hoist would fail like that which is dangerous glad your getting your money back
Old Aug 7, 2009 | 10:13 AM
I sent the inquiry to Costco and they haven't gotten back yet. Problem is it is brand new but I bought it 1 yr ago. Manufacturer instantly responded, but not sure if I want a replacement from that same brand. I don't think so.
Old Aug 7, 2009 | 10:55 AM
rvamaxima's Avatar
I like using a leveler for minute angle adustments, especially when you don't have a helper. But mostly just to keep the chains off the engine and causing damage.
Old Aug 7, 2009 | 11:05 PM
Good point, your right - I noticed the leveler keeps the chains kind of on the outside. I was wondering if the rocker covers would get damaged from the chains, but it didn't seem to do any damage. I also put rags in between to pad it a bit, in case it did pull against it.
See photos in 3rd gen section of leveler.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
Vequity
Sep 10, 2015 05:26 AM
