Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
Rubber notched lifting blocks
Old Oct 29, 2009 | 02:31 PM
chillin014's Avatar
I remember using these when I worked at DiscountTire for cars and trucks with the metal pinch/welded flange that runs the length of the vehicle. I understand the concept of the flange, for use with a scissor jack...but like any normal person, I use a lift or a regular hydraulic jack to raise my car. The problem is the damage it causes to the jacking points.
I want to buy some of these blocks but I cant seem to find any information ANYWHERE online about them. Surely somebody produces something.
I've tried jack pads, and they dont help too much. So , does anybody know?
Old Nov 7, 2009 | 06:53 AM
madstylez's Avatar
I just use wood blocks with the jack. Works pretty well and doesn't damage to the pinch weld.
Old Nov 7, 2009 | 07:03 AM
chillin014's Avatar
that could work I suppose, I just figured rubber would be more forgiving. I worry about a block of wood slipping off of my 4 post lift but I guess if it was only a few inches or so tall, just enough to give relief to that pinch, it may not be a problem
Old Nov 12, 2009 | 07:17 AM
DanNY's Avatar
Ad·min·is·tra·tor
go to your local hockey rink...snag a used hockey puck.
cut a groove in it and whammo instant jack pad.
it's plastic so it's a little more forgiving than steel/wood.
Old Nov 12, 2009 | 09:20 AM
Jmahad01's Avatar
It would probably be better to notch a good small piece of 2X4 rather than a peice of plastic. Wood would be stonger in my opinion lol.
Last edited by Jmahad01; Nov 12, 2009 at 11:01 AM. Reason: I mis-spell everything.
Old Nov 12, 2009 | 10:53 AM
DanNY's Avatar
Ad·min·is·tra·tor
Originally Posted by 94maxteamrtv
I would probably be better to notch a good small piece of 2X4 rather than a peice of plactic. Wood would be stonger in my opinion lol.
ever get hit with a hockey puck? it's not your normal piece of plastic.
Old Nov 12, 2009 | 11:04 AM
Jmahad01's Avatar
Can't say that I have. To each is own I guess.
Old Nov 14, 2009 | 05:05 AM
Matt93SE's Avatar
STFU n00b!
Thaaaaat's why Dan is always in such a bad mood!
Why not just do what smart people do and use the frame rails and suspension pickup points on the car to jack it up instead of the pinch welds? There are many suitable lifting points on the car for floor jacks and lifts.
Old Nov 21, 2009 | 03:05 AM
1993-VG30E-GXE's Avatar
Hockey puck is a good idea. I'm trying to figure it out tonight with this Honda I'm trying to support - there's nowhere for the jackstands to go besides those protrutions on the pinch welds. So I ripped the bottom off of downhill ski boots that have rubber, but it doesn't work too well.
So i'm going to buy 4 pucks tommorow and try it. By the way 94 Max, the hockey pucks are really tough, they'll kill you if they hit your head hard enough. The practice pucks are even heavier - 10oz vs 6oz. Both are made from vulcanized rubber - probably even stronger than those jack pads, and certainly safer than wood I would think!!!!
Old Nov 21, 2009 | 03:44 PM
niceguy's Avatar
I use the suspension hard points out of habit....on the beater, a '93 Altima, I used the floor jack under the frame rails and now they're bent/pushed up so I went back to ramps and suspension points...
Old Jan 20, 2010 | 05:04 AM
wraabe's Avatar
Does anybody have a schematic or pics on where the suitable lifting points are located?
Old Jan 20, 2010 | 05:11 AM
wraabe's Avatar
Floor Jack Lifting Locations
I also had the same experience as niceguy, where the subframe rails bent when using them as jacking locations. Where are the suspension hard point jacking locations? Also, is there an acceptable location to jack up the whole front/rear end?
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
howardis
Dec 11, 2019 06:10 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
