Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
how do i jack up the engine?
Old May 1, 2012 | 09:09 PM
Ryan Whitehead's Avatar
Ive heard that i should get some plywood and go from the oil pan, but other tell me it wont hold... whats the best way to do it? (Im trying to change the timing belt...)
Old May 3, 2012 | 05:18 PM
Snypa's Avatar
hoisting from from above would be best. Lower oil pan is soft, so that wont be a good idea. Something more solid though.
Old May 4, 2012 | 08:42 AM
ranmas2004's Avatar
You really dont "jack" up the engine. You can hold the engine in place if you swapping a tranny or changing motor mounts. What are you trying to do? I think after that we can get you a better answer.....the question is phrased wierd and unclear what you mean.
Old May 4, 2012 | 08:46 AM
Get a hoist.
Old May 11, 2012 | 06:16 AM
GStrength's Avatar
http://www.harborfreight.com/1000-lb...bar-96524.html
I actually used this engine support bar when I changed my clutch kit. It works well and you can adjust the lift while it's support the weight of the engine.
Old May 11, 2012 | 11:24 AM
DennisMik's Avatar
How do you use that bar? Do you set it across the fenders in the engine compartment?
jsmith24
Feb 1, 2016 12:35 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Socalstillen
Sep 20, 2015 11:46 PM
14GmMax
Sep 19, 2015 11:32 PM
seesole
Sep 14, 2015 12:38 PM
