Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
car sticks in gears someone help
Old May 11, 2012 | 05:56 PM
ezkill89's Avatar
I have a 2000 nissan maxima. Well this is what happens, I might drive it a bit agressive or in high heat and my car starts sticking in 2nd gear and does not want to go past that BUT if I shut off the car while I'm driving and restart the car the problems gone. This to me it feels like its a mechanical problem I just wanted to see if anyone else has had this problem with there 5th gen max. Because everyone tells me that the tranny is good so is the motor but noone can really figure out what the problem is unless its happening, can this maybe be a sensor going bad?
Old May 12, 2012 | 08:50 AM
L36's Avatar
L36
Its probably overheating, like you said this only happens in high heat.
Invest into an aftermarket transmission cooler. Try avoid pushing the trans too hard in heat, you will cook the clutches inside and it will cost you a lot to repair.
Lakersallday24
Jun 16, 2019 01:35 AM
Quickgtp
Apr 13, 2017 03:30 PM
JMag90
Aug 25, 2015 09:17 AM
maxima-junky
Aug 13, 2015 09:59 AM
MikesChevelle
Aug 10, 2015 10:53 AM
