Crank position sensor signal modification to adjust timing
Old Dec 9, 2000 | 03:27 PM
MardiGrasMax's Avatar
Does any one know if the crank position sensor signal is analog or digital?
An EE friend of mine thinks it would be easy, for him atleast, to build a module to advance/retard this signal so that we could play with the base ignition timing.
Hmm do you think that modifying this signal would also effect the fuel injector timing?
Mabye it would be easier to intercept all 6 coil trigger wires and modify their signals?
Any help is appreciated!
Old Dec 10, 2000 | 09:37 AM
1MAX2NV's Avatar
Let me read up on my FSM today and I'll see if I can give you more info.
Old Dec 10, 2000 | 10:37 AM
Keven97SE
Digital. All it is is a magnetic pickup that triggers once per rev. from the crank and indicates TDC to the ECU. It's located right under the crank pulley and is triggered by the two tags the stick out from the base of the crank pulley.
Take a look at the sensor yourself. You'll see that you just need to find a way to move the sensor to the right such that it triggers a little earlier (TDC is no longer TDC, but a degree/two/etc BTDC), you'll trick the ECU into starting all ignition firing a couple degrees earlier.
I'd like to find a spare (used) crank position sensor (REF) to mess with. Bore out the bolt holes so that there's room to move it, and remove the locating pin on the sensor. I think that's all that's needed.
Old Dec 10, 2000 | 11:13 AM
Cool, I'll have a look.
What signal does the injectors use as their reference for when to fire?
Is their a sensor on one of the camshafts or somthing?
kjlouis
Nov 24, 2018 06:09 AM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
