Anyone Have Problems w/ Their Ignition Switch?
I switched out the starter to my 95 SE about 1 month ago and the mechanic told me that my ignition switch will also need to be changed. It is getting worse and I need to fix it...Now, am I going to have to get a new core with a new key and have to "carry" around 2 keys - 1 for the ignition and 1 for the Doors /Trunk - or is there a way to fix it without having to do all that?
Lets hear the wealth of knowledge from this forum....
Thanks for your help...
Re: Anyone Have Problems w/ Their Ignition Switch?
Anyone???
I have knows of a few 95 models to have problems with ther switch, it was a problem that you turned the key and the car wouldnt turn over. Something with the way the key was positioined in the switch. Ask 88maximase he has this problem on this 4th gen .
mike
mike
mike
mike
Hope this can help someone else....
Well - I went to the Universal Nissan Dealership and they told me it seemed like the Switch assembly. Which was only $40. So I tried it .... and thank you Lord. That was the problem.... So if anyone has a startup problem and you know it is not the battery and the starter then try part # 48750-1E411...
Thanks...
Flaky Ignition
Is that the entire part number for the ignition switch assembly, and is it relatively easy to install? For the past several months, when I start my car sometimes I will turn the key all the way and not a sound. It will start the second time. I've been suspecting an ignition problem. But last night, for the first time, it would not make any sound after turning it 5-6 times. I checked battery, starter and alternator and all were fine, so I believe this assembly you refer to is my problem. I also have a '95 Maxima.
Re: Flaky Ignition
I also have a '95. This has been an on-going problem in my car since the first day I bought it in '94. I'm not sure if this part would help me any, because, I too, thought there was something wrong with my ignition switch when I was experiencing these problems. In fact, the dealer checked my ignition signal with a computer scan tool, and it turned out that there was signal going to the starter, but no crankage! This meant my ignition switch was doing what it was supposed to do. It turned out that Nissan had numerous problems like these in their '95 and '96 models. But, it was the starters, not the ignition switch. But, maybe Nissan was wrong and overlooked something, like the switch assembly your referring to. I'm going to buy this part and see if it will cure my on-going problem. Good job on this discovery! I hope this works, because I'm on my 3rd starter now!
mikeg75
11-30-2015 05:12 PM
