RSB causing my car to squeek...A LOT !HELP!
Old Jul 23, 2002 | 10:57 AM
Newman's Avatar
a few weeks ago i posted this thread:
HELP!!! Squeeking coming from in front of my rear driver's side
something was squeeking under my car and i couldnt figure out what it was. i took it to the dealer today and they solved the problem by removing my RSB.
now, i know i should have considered the RSB to be a possible problem. and i DID. i even readjusted it but the problem still persisted. if you read that original thread you'll see the steps i took.
so, now that i know it was the RSB that was causing the squeeking i have a question....WHY??
many people have an Addco RSB and their cars do not squeek. what do you think was causing mine to squeek. the RSB had been on for weeks before the squeeking started and i didnt mess with anything on the RSB to cause it to happen. i did lower my car and that is when the squeeking started.
anyway, there is too much to say. bottom line is: i want to put the RSB back on but i dont want the squeeking. what do i do?
Old Jul 23, 2002 | 11:45 AM
02maxima's Avatar
have you tried any of that suspension grease on it .?
Old Jul 23, 2002 | 11:46 AM
Lime's Avatar
Do a search on Addco RSB ... if I remember reading, something has to be replaced on those RSB's.
Old Jul 23, 2002 | 12:28 PM
gjabo178's Avatar
how long have you had the rsb...mine squeek for a couple months, now it's silent...I believe it's a matter of time.
Turn up your radio
Old Jul 23, 2002 | 12:44 PM
Wizeguy's Avatar
I believe the Addco bar comes in two flavors, rubber bushings & graphite injected polyurethane bushings.
Five bucks says you have the rubber ones.
Old Jul 23, 2002 | 01:21 PM
ericdwong's Avatar
I had this problem, but it didnt crop up until 2 years later. And even so, it only happened when I went up a curb'd driveway. Anyway, the solution is to remove the sway bar bushings, and grease them. I used trailer hitch ball grease becasue that stuff is very resistant to water, etc. So far, excellent results.
Old Jul 23, 2002 | 01:42 PM
Newman's Avatar
would you like cash or check?
so i have the rubber ones. what should i do? grease them like Eric suggested?
Old Jul 23, 2002 | 01:43 PM
soundmike's Avatar
Very sound, Mike
So from a visual standpoint, how does one know if the bushing is rubber or the other?
Old Jul 23, 2002 | 01:57 PM
Larrio's Avatar
The Definitive AE Master
i had the same problem and the dealer blamed it on the rsb eventhough the sound was coming from the front right side of the car. I just went down and tightened everything cause it some got a little loose and straightened the brackets up. But I don't have a addco.. might not help that much
Old Jul 23, 2002 | 02:00 PM
acMAX's Avatar
Re: RSB causing my car to squeek...A LOT !HELP!
[i]Originally posted by Newman
anyway, there is too much to say. bottom line is: i want to put the RSB back on but i dont want the squeeking. what do i do? [/B]
does the squeeking come from the rear end of the car or is the sound more prominent from one side? (i.e: rear left or rear right)
Old Jul 23, 2002 | 02:02 PM
Newman's Avatar
Re: Re: RSB causing my car to squeek...A LOT !HELP!
it was actually ONLY on the driver's side until a few days ago. but even after the passenger side started doing it, it was much more obvious on the driver's side.
Old Jul 23, 2002 | 02:40 PM
costcowholesale's Avatar
Newman where did you get yr addco with rubber brushing? it looks like most addco I've seen comes with the other kind
Old Jul 23, 2002 | 07:06 PM
Newman's Avatar
got it from custommaxima
to be honest, i wouldnt be able to tell you which bushings i have except for the face that Jason (Cutlr7) helped me install it and he pointed out to me that i did not have the same bushings as him. and he said he had the polyurethane bushings. so im guessing i DONT have them.
Old Jul 23, 2002 | 07:18 PM
I just got this from greg
quote[
They come with urethane bushings.
Thanks,
Greg
-Custom Maxima Enterprises-
www.CustomMaxima.com
Old Jul 23, 2002 | 07:37 PM
Newman's Avatar
quote[
Thanks,
Greg
any one have a picture of the polyurethane bushings? i seem to remember Jason saying his were red whereas mine are black.
lets just say i have the non-polyurethane bushings. if i were to get the polyurethane ones would that prevent the squeeking noise?
Old Jul 23, 2002 | 07:41 PM
soundmike's Avatar
Very sound, Mike
Doubt it, some of the poly-u bushings came in black as well.
this red stuff?
Old Jul 23, 2002 | 10:00 PM
Newman's Avatar
i was talking with another friend of mine about it tonight. he said my bushings were definitely the rubber bushings. not polyurethane.
did you order it a long time ago?
Old Jul 23, 2002 | 10:25 PM
Newman's Avatar
middle of April.
Old Jul 23, 2002 | 10:27 PM
Newman's Avatar
i emailed greg. hopefully we'll figure something out. thanks for all the help.
Old Jul 24, 2002 | 07:34 AM
95Max's Avatar
Rubber bushing will generally not cause squeeking. I have urethane on my front bar and they were queeeking. I removed them and lubed them with waterproof trailer grease. (avail from any marine supply for about 3 bucks). No more squeeking.
Old Jul 24, 2002 | 11:34 AM
2DMax's Avatar
Mine did the same, went away after sometime.
Turn up your radio
Old Jul 24, 2002 | 11:47 AM
Cutler's Avatar
RSB
I was the guy who helped install this on his car, I installed two of these on both my maximas and never had any squeeking. I think he will resolve this problem with the bushings that Addco is sending him. The Polys are on the way
Old Jul 24, 2002 | 11:58 AM
soundmike's Avatar
Very sound, Mike
Ok, i'll ask one more time
How does one know if the bushing is rubber or poly-u just from looking at it?
Old Jul 24, 2002 | 12:47 PM
Re: RSB
is he paying addco for the new brushings?
Old Jul 24, 2002 | 01:23 PM
Cutler's Avatar
Re: Re: RSB
Not that I am aware of
Old Jul 24, 2002 | 01:32 PM
97MaxGurl's Avatar
Chick specializing in rounding up 100+ Maximas
that almost sounded perverse
I had Addco rsb for 1 month or so before I switched over to Stillen. My car was lowered on both instances. I had absolutly NO problems with the Addco rsb (easily installed, no noise at all).
As a matter of fact, I may sell my Stillen rsb and go back Addco later b/c I'm going through some stereo and a/c woes and need some cash
Anyway.. just want to share my good experience with Addco here.
Old Jul 24, 2002 | 07:10 PM
Newman's Avatar
you can't really tell for sure just by looking at them. originally i thought the polys were red and the rubber ones were black but according to Addco the polyurethane ones come in black sometimes as well.
but, if its red its almost definitely polyurethane. if it's black then it is most likely rubber but not definitely.
no, they are sending them at no charge.
oh, i wasnt knocking Addco at all. i had the bar on my car for a couple months with no problems but the squeeking started right after i lowered my car.
im going to lube these polyurethane bushings when i get them and use those. hopfully that means no more squeeking.
Old Jul 24, 2002 | 07:58 PM
maxstyle98's Avatar
Re: Ok, i'll ask one more time
You can tell by feeling/ squeezing it. The poly will be dense, stiff, and have a wax like feel to them. The rubber will be soft and feel like a tire.
But if you got it from Greg im sure their poly. I have lots of squeeking on mine, I'm going to try grease, and see what happens.
Old Jul 24, 2002 | 08:15 PM
soundmike's Avatar
Very sound, Mike
I just looked at my bushings and there seems to be an inner layer that's smooth. It doesn't feel waxy and it most definitely doesn't feel like a tire.
I got the whole set from Cattman. It did seem like the package was an open-box item though (e.g. scratches on the bar, pack w/ bolts were open)
Old Jul 24, 2002 | 08:44 PM
97MaxGurl's Avatar
when in doubt... always lube
credit to DanNY
Old Jul 24, 2002 | 09:44 PM
DRAKO-MAXX1
HMMMMMMM..... I just got my bar from Cattman last week and mine also looked like and open-box item bushings and bolts all over the place. Had the bar on for a few days now nice upgrade and no knocking......yet?
Old Jul 24, 2002 | 10:09 PM
Newman's Avatar
Re: Re: Ok, i'll ask one more time
assuming mine ARE the rubber ones, i wouldnt say it feels like a tire. the way i described it to the Addco rep on the phone was that it feels like a "spongey plastic". not quite as bouncy and sticky as most people generally picture rubber to be.
Old Jul 24, 2002 | 10:59 PM
I think those who brought from cattman, u got the rubber ones
http://forums.maxima.org/showthread....&highlight=rsb
he didn't say anything abt urthurne burshigns
Old Jul 25, 2002 | 07:54 AM
soundmike's Avatar
Very sound, Mike
His site says "Comes standard with ADDCO’s “optional” urethane bushings." So i guess that would be a given.
Lakersallday24
Jun 16, 2019 01:35 AM
Ray229Harris
Sep 16, 2015 08:16 PM
JMag90
Aug 25, 2015 09:17 AM
scarletsosa
Aug 17, 2015 09:09 PM
Samedi
Aug 13, 2015 04:05 PM
