Optimum tire pressure?? F/R be different??
Old 07-30-2002, 08:00 AM
gjabo178's Avatar
The maximum pressure, as it states on the tire, is 30lbs.
For best performance what is the recommended pressure?
I'm running Kuhmo 225/50/16
gjabo178 is offline
Old 07-30-2002, 08:22 AM
njmaxseltd's Avatar
The recomended tire pressure for your car is located on a sticker in the lid of the arm rest between your front seats.
njmaxseltd is offline
Old 07-30-2002, 08:52 AM
Lime's Avatar
If you choose to run other pressures, run low at the track, and high at auto-x.
Lime is offline
Old 07-30-2002, 08:58 AM
gjabo178's Avatar
Yes that would the right answer if I had stock size tires.
What is considered low and high?
gjabo178 is offline
Old 07-30-2002, 09:11 AM
Gr8bone's Avatar
I'm not running stock size and I found that the recommended TP has the best traction/ride than any other TP's I would say low/high is + or - 3-4lbs 5 at most anymore and it would have a negative effect
Gr8bone is offline
06-06-2017 02:01 PM
Serotta33
09-17-2015 12:14 PM
Quick Reply: Optimum tire pressure?? F/R be different??
