engine temps..
Old Aug 1, 2002 | 05:56 PM
nismo-max500's Avatar
engine temps..
if you have your heat on in your car, will it help the engine cool off more? thanks -max all the way!
Old Aug 1, 2002 | 06:04 PM
iwannabmw's Avatar
Re: engine temps..
Running the heat will take some away from the engine. If everything is working properly, the system will regulate itself stay right where Nissan designed it to. If the car starts to overheat, turning on the heat is the best way to try to keep it under control.
If you're question was under normal conditions, will using the heat reduce the engine temp any, then the answer is no.
James92SE
142
Jan 2, 2024 09:23 AM
homewrecker
Sep 24, 2015 07:01 PM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
