Xenon=electrical Fire?
Old Aug 16, 2002 | 08:48 PM
maxichic's Avatar
I really wanted green headlights so i got the xenons and they caused the headlight harness to melt; i also heard of 2 reports where they started a fire? Is this possible? if so are there any safe bulbs that i can put in and still have the green tint (my max is sage mist green)
Old Aug 16, 2002 | 08:54 PM
theblue's Avatar
Re: Xenon=electrical Fire?
if you go cheap then this is what happens... you should get a headlight harness upgrade if you run ANY overwattage bulb. The best way to get the results you want is to buy a HID kit but they are around $500 on average.
Old Aug 16, 2002 | 11:05 PM
max1ma97se's Avatar
same thing happened to me, if you go to high of a voltage with a bulb its gonna get hot and soon or later it's gonna melt the harness and could cause a small fire
Old Aug 16, 2002 | 11:11 PM
costcowholesale's Avatar
I burn my fuse, harness didn't met, did my fuse prevented a meltdown??
Old Aug 17, 2002 | 07:44 AM
RastaManMax's Avatar
Can't you just put in the stock wattage bulb instead of a higher wattage one?
Old Aug 17, 2002 | 12:25 PM
maxichic's Avatar
Re: Re: Xenon=electrical Fire?
yea but if i did that then i wouldn't have the xenon green anymore and i really want to keep the headlights green, but can't i just get a new harness at strauss or will this also happen again until i change the bulb?
Old Aug 17, 2002 | 12:56 PM
carnal_c30's Avatar
Former Sponsor
Re: Re: Re: Xenon=electrical Fire?
you can order an upgraded wiring harness for about 40 bucks from www.carparts.com or maybe www.nopi.com this will solve the problem
Old Aug 17, 2002 | 08:13 PM
00MaxSE's Avatar
Pointy Elbows
Coolbulbs.com also has the heavy duty wire harness. I was thinking about getting one.
Old Aug 17, 2002 | 08:32 PM
TimW's Avatar
The silent but deadly Moderator
my 2k2 HIDs are only 35W
Old Aug 17, 2002 | 11:32 PM
maxichic's Avatar
where did u get those at?
Old Aug 17, 2002 | 11:39 PM
Soon2BMaxed's Avatar
they are TRUE HIDs not bulbs.
Old Aug 18, 2002 | 11:35 AM
maxichic's Avatar
thats like $400 right?
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
salty318
Sep 29, 2015 01:21 PM
