VI problems round 3.. works, but will not return
Ok so my VI is working , sort of , thanks mardigras, jay25, speedtrip, mr cranman, iansw, dave b, and others.
BUT when it turns on, the actuator comes down, but will not go back up when below 4800 rpms.. even at idle it will not come back up. It is not because of the vaccum, I can freely move it back up.
So my question is did I hook something up wrong.
I have the vaccum line hooked up to the check valve of the NAPA cannister, then the line out of the cannister to the actuated port of the MAP/baro switch, the line the the VI actuator arm connected to the always open port of the map switch which opens to the cannister at 4800 rpms. so there is a way for the air to be released
HELP
It happens in neutral and I drove down to get gas.. about 1/2 a mile.. and it was still down..only passed 4800 rpm once.![got me](https://maxima.org/forums/images/smilies/ne_nau.gif)
I am about to drill a small hole and put a darn return spring on.. BUT I am sure that will cause to much work for the vaccum.
Again ANY help would be great
thanks
bags
HELP
thanks
bags
Im getting worried that my VIM will have lots of problems. Im now leaning towards having a professional install it. Good luck with your problem my friend. Remember, you guys with the VIM problems are the pioneers and your mission to solve the problems will help lots of other like me in the future. Thanks.
Peter
Peter
Peter
Peter
BTW I thank you for the compliment, but I did not pioneer this, mardigras was the 1st that I know of with speedtrip and ians and mr cranman behind him.
I am about the 10th-15th person to do it.
With that being said.. When you get yours, AIM or email me at bags533@aol.com with any question
This board has lots of info and so does xhypex website. And the problems I had I will make sure you do not make.
Just get everything in order before you start. 2 of my 5 problems were due to lack of properly preparing.
Good luck
Re: VI problems round 3.. works, but will not return
The closed or "off" position should be dictated by lack of vacuum AND a properly functioning vacuum actuator lever (that brass-colored bell shaped thing). It's supposed to have a spring that exerts pressure on the valve rod assembly to the closed position when no vacuum is applied. If I'm ready you correctly, it's not doing that? When the car is not even on, can you open the valves with almost no effort or does it require a good tug?
HELP
HELP
Or are you saying the actuator pulls the butterfly valves open the first time you hit the 4800 rpm set point and then stays open?
Does the actuator arm close the butterfly valves as soon as you turn you maxima off?
When the butterfly valves stay open have you tried disconnecting the switched ground from the relay?
Re: Re: VI problems round 3.. works, but will not return
Originally posted by speedtrip
Are you saying that the actuator is pulling the butterfly valves open before the rpm set point and holds the valves open all the time?
No, just tried it
man I am gonna owe you big time after this
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
when you say closed or off.. what exactly are you referring to ? 6 butterfly valves and actuator arm?
What spring are you referring to ?
I just went and checked.. it's harder to pull the arm down, opening the butterfly valves, and easier to push up, closing the valves... not really a tug but some force is required
thank you
edit.. maybe this will help..
when the car is off and i manually pull the rod down opening the valves it does NOT return to the up postion closing the valves
does this help yall help me?
Re: Re: Re: VI problems round 3.. works, but will not return
Re: Re: Re: Re: VI problems round 3.. works, but will not return
SHOOT.. man looks like a drilling I will go..thank you for your help.. wonder if I can take that thing aprt and fix the spring..hmm
looks seald to me..how sealed and by what I do not know..but I can break anything..man i thought I would be done by now..oh well
thanks mishmosh
Re: Re: Re: Re: Re: VI problems round 3.. works, but will not return
thanks mishmosh
thanks mishmosh
If it definitely is busted, you can try to take it apart to fix the spring portion but I also may be in a position to help you. as you may know, I have a 35U variable intake that RoadBeast sent me (the rat bastrd). ...anyways, the actuator on it has a dent but apparently works. PM me your address and I can send it out to you if yours is busted. Maybe Mr. Cranman can have a replacement sent out with the next order because you should definitely have a new working one.
Re: Re: Re: Re: Re: Re: VI problems round 3.. works, but will not return
Don't drill it! You may ruin the suction/lever part. Of course if it doesn't work right anyways, then I guess you have nothing to lose. Can you post a pic of how the arm connects to your butterfly rod just to rule that out?
www.bags533.com/VI1.wmv
Remove the hose between the actuator and map/baro switch. Pull back the actuator arm to open the butterfly valves and release it. If the actuator arm snaps shut then I would say the map/baro switch is the cause. If the actuator arm continues to stay open like in your movie then I would say the actuator is broken.
EDIT Ok
So I am taking my actuator off the car.. guess what? the return spring WORKS!!!!
Apparently there is more friction INSIDE the intake than the spring can handle
I am guessing that the valve rod is slighty bent.. thus making it hard to return
I WILL SOLVE THIS and I WILL HAVE A WORKING VI..OH YES IT WILL BE MINE
<insert physco laugh here>
thank you to Mishmosh,speedtrip
Does anybody know if I can get one of these from another nissan??
In a junkyard maybe? Off of a 2k something? Pulsar maybe? 3rd gen max?
Like I said before dude, I have a used one that is doing nothing for me... just give me the word and it's yours.
Edit: if you want to perform surgery on yours, it looks as if the actuator is formed by two halves joined at the lip that goes around it. You might be able to take a sharp, small instrument and peel back the edge to separate the housing.
HELP
thanks
bags
HELP
thanks
bags
HELP
thanks
bags
HELP
thanks
bags
Just my thought,
John
Here's a way to see if it's the actuator. Try sucking on the hose that connects to the MEVI. It should open with suction and when you release it, it should close. If that works, its a problem with something else. If it doesn't then the rod could be bent or your actuator could be broken.
Apparently I bent the rod slightly when I put it in. Took it out and found a flat surface and using a rubber mallet got it flat again.
IT WORKS
Mrcranman- thank you.. I understand why you did not.. It's really NOT a problem.. BTW ALL of the parts I got work, so I misspoke earlier.
Thank you everyone.. BUT it was worth it.. ran the car a little last night.. OH BOY
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
Yeah I read through the post after I had commented...I realized that you had figured it out that it was a bent rod. I'm really glad that you got it up and running, and I'm sorry about the troubles you had
. Have fun with the mod
-John
![Frown](https://maxima.org/forums/images/smilies/frown.gif)
-John
-John
-John
Thanks man..it will be a fun week or 2 playing with the new toy.
BTW if anybody asks you suggest /8 inch hose.. I only was able to find it as a fuel line..but it seems to work better with less leaks. HARD to get on but once it's on..it stays on.
![kiss](https://maxima.org/forums/images/smilies/kiss.gif)
jerrod99_se-l
08-27-2015 08:27 PM
sonic7
08-20-2015 12:23 PM
