Lube when installing metal matrix pads
Old Aug 22, 2002 | 10:57 PM
BugNout
What type of grease should be used to lube the shims and caliper components when installing metal matrix pads with x-drilled rotors?
Old Aug 23, 2002 | 04:26 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Re: Lube when installing metal matrix pads
same grease that you use for all brake pads...... disc stop, quiet stop blah blah blah yackity smackity
Old Aug 23, 2002 | 05:01 AM
njmaxseltd's Avatar
The only items that get greased are the pins that the caliper floats on. Remove them, clean out the old grease and apply HIGH TEMP grease, then put them back in. You should not grease the external hardware of your brakes.
Use quiet stop anti squeal on the back of the pads before you put the shims on.
lowpost99
Oct 26, 2025 06:53 PM
bbsitum
Sep 11, 2015 04:55 PM
pjgreek
Sep 9, 2015 09:30 PM
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
