Urgent, help me
Old Aug 25, 2002 | 06:13 AM
jqhao's Avatar
Urgent, help me
yesterday I put a coverage for my tilting steering wheel when the engine is closed. At the beginning, the wheel can move a little bit even it is locked. Since the coverage is tight, I used more power. I found that the wheel moved about 60 degree comparing with the original position and it can not moved after I finished. I tried to ignite the car, however, I can not move the key. At the same time, the security alarm is on. Currently,
1) The wheel can not move;
2) I can not turn the ignition key.
3) when I open the door, the security alarm appears and it disappears after I closed the door.
What is the problem? can I just try to move the wheel to original position? thanks for your help, I am anxious.
My car is Nissan Maxima 1993.
Old Aug 25, 2002 | 06:27 AM
asu174's Avatar
Clay Aiken has fancy genitals
Re: Urgent, help me
What are you talking about? A "coverage"?
Old Aug 25, 2002 | 06:40 AM
jqhao's Avatar
In my post, the wheel means the steering wheel.
Old Aug 25, 2002 | 06:46 AM
Sly's Avatar
Sly
I think what you're talking about is the locking mechanism between the ignition switch and the steering wheel. When you turn the engine off and pull the key out, if you turn the steering wheel far enough it will lock in place. But since you have no power steering, the steering wheel pushes back against the lock with enough force to jam the mechanism and prevent you from unlocking it with the key. What you have to do in that situation is turn the steering wheel a little more and hold it off the lock while you turn the key to unlock it. the security system should have nothing to do with this. I'd still like to know what a "coverage" is.
Old Aug 25, 2002 | 06:57 AM
jqhao's Avatar
Thanks for your reply.
Since the steering wheel is tight, do you think that it will be helpfut if I use the jack to lift up the front a little bit?
I am afraid that I use too muck power to crack the steering wheel.
coverage is "steering wheel cover", maybe I use the wrong word.
Thanks again.
Old Aug 25, 2002 | 07:02 AM
95maximase's Avatar
you are not very clear on your explanation
It is difficult to understand your problem from the way you describe it. I don't understand the terms you are using nor the description of the problem. You may want to have a mechanic or friend near you check this out.
Old Aug 25, 2002 | 07:09 AM
Sly's Avatar
Sly
Thanks again.
Getting the front wheels off the ground will help but you should not need to do that. The steering wheel is pretty sturdy and should not break. You only need to turn the steering wheel a very small amount to take pressure off the lock mechanism in order to unlock it with the key.
Old Aug 25, 2002 | 07:46 AM
jqhao's Avatar
I appreciate the help from every guys.
Following your advice, I have handled this problem.
Thanks again.
Old Aug 25, 2002 | 09:50 AM
ORBRIT's Avatar
..also probably not a good idea to ignite the car..
teeezmaxSE
30
Aug 16, 2005 11:46 AM
PoePoe2797
Jun 18, 2004 06:31 AM
