Denso Iridium Spark Plugs
Old Sep 3, 2002 | 10:58 AM
420MAX's Avatar
Anyone running these plugs in their ride? Let me know how they are.
Old Sep 3, 2002 | 02:10 PM
Mishmosh's Avatar
Re: Denso Iridium Spark Plugs
Yeah. No problems... Can I appreciate improved performance over stock? nah...
Old Sep 3, 2002 | 02:29 PM
420MAX's Avatar
Re: Re: Denso Iridium Spark Plugs
What did you pay for them? Apparently the Corp. office is not to far from my pad and I can will call the plugs for $11.99+tax. Good deal?Let me know.Thanks
Old Sep 3, 2002 | 04:58 PM
HondaKiller718's Avatar
Re: Re: Re: Denso Iridium Spark Plugs
Stick with stock, you are wasting money.
Old Sep 3, 2002 | 05:07 PM
Mishmosh's Avatar
That's about what I paid. If you go with NGK iridium, you can get them for much cheaper...
Although you can't lose with stockers, sometimes I just like to try things if it'll make a small improvment. I don't mind swapping them out in 30k miles because I only rack up 10-12k miles per year.
Old Sep 3, 2002 | 06:10 PM
Green 2kSE's Avatar
Re: Re: Re: Re: Denso Iridium Spark Plugs
Then you would be better off getting NGK copper plugs.
Old Sep 3, 2002 | 11:28 PM
Kevin Wong's Avatar
They do wonders for many different Honda cars and they are stock on the Toyota Matrix, I believe. I just installed some on my friend's SI and we couldn't feel any power gains. The car ran smoother, but it may have been since the plugs were new compared to his 20K mile used plugs. I using the NGK Platinum and until someone can dyno verify the gains from fresh NGK Platinum to NGK Iridium to Denso Iridium, I'll just stick with the factory recommended plugs.
Old Sep 4, 2002 | 07:29 AM
stose95's Avatar
I tried them for a week on my 2000 max. didnt really notice anything. for some reason i felt a slight improvement in fourth but thats it. If you really want to try them, I will give mine $25 shipped. not sure if they will fit though
Old Sep 4, 2002 | 09:31 AM
Guru's Avatar
I dyno tested them on an extremely modified Honda VTEC motor and noticed absolutely NO gains. I also have seen two failures with iridium plugs so I no longer use them at all. Stick with stock unless you're running turbo or SC in which case I suggest a colder heat range.
Old Sep 4, 2002 | 09:42 AM
420MAX's Avatar
The reply is much appreciated by all. I'm thingking hondkiller 718 said it best. I think I'll stick with stock and spend my $ on something else.Thanks
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
