What grit sandpaper should i use to take off
go to the hardware store and ask the
guy in the paint department. they'll tell you what to get. when i went he siad something about wet sanding, and take your time painting don't rush it. i was going to paint my rims black too, but i never got around to it. do you guys think these would look good black? not a bark black.
<img src="http://www.geocities.com/perlmax90/image019.jpg">
How about removing chrome?
I want to try and polish a wheel. I'm picking up a damaged crhome one (the chrome is peeling bad). Is there a recommended way to remove the rest?
Also, what's the best method to get a polished finish?
Originally posted by Tomo
waht grit sand paper shoudl i use to take the peelign clear coat off my stock 91 rims. i also plan on repainting them any sugestions. Im planign on paiting them black
sandpaper
Most of the Chilton books say use a 600 grit sandpaper on primer and steel wool on the clearcoat. I would start with the steel wool and see if that makes a differnce. Probaly have to go up to 600, but check with a body shop if you can wait.
I heard that paint will peel unless it is done with a professsional spray and that powder coating is a much more durable finish. Do a search to find out more!!
sctludwig
09-01-2022 01:32 PM
lowpost99
10-20-2015 07:42 AM
rwatt1981
02-17-2004 08:25 PM
