prob w/ground controls
Old Sep 6, 2000 | 10:12 PM
j dogg
i had some ground control coilovers installed and the front ones make a clunking and pinging sound when i turn the wheel while traveling at low speeds or at a dead stop. how do i remedy this problem?
Old Dec 23, 2002 | 12:47 PM
Supermax95's Avatar
change your strut mounts
Old Dec 23, 2002 | 01:26 PM
Nismo's Avatar
teh noises while turning is because your strut bearings are not lubes or damaged
Old Dec 23, 2002 | 01:28 PM
hockeyghst's Avatar
yeah change them if u wanna waste your money.....
....i had weapon r coilovers and they made the same noise you are describing.....if i remember correctly the noise u hear is the spring turining and metal rubbing on metal...i just got used to it....at first it was annoying but i got used to it...and after a while it seemed to not make as much noise as i though it was making.
Old Dec 23, 2002 | 04:57 PM
ohboiya's Avatar
I'm having some problems with mine ... but I hear a clanging from the right rear set-up. Have you guys encountered this before or heard of this problem?
It sounds like a ball bouncing on a metal pan but with each bounce it the clanging gets softer ... hard to describe .. except it's one royal PITA and my passengers freak out!
Old Dec 23, 2002 | 05:15 PM
lcf's Avatar
lcf
Ya know, wack $hit like this is one of my greatest fears about dropping my car. I hate it even when my brakes squeel!!
Oh well, gotta do it though... eventually. Sigh.
Old Dec 23, 2002 | 10:47 PM
rob van dam's Avatar
ok here is how to get rid of all the noise...
I have ground controls on my tokicos......i had noise when i turned and a knocking noise in the rear....
for the FRONTS here is what you do---at the shop i got mine put on..they had these rubber disks that we put between the spring and the metal seat at the top and bottom of the spring.......so the spring does not touch metal it just touches the rubber disk.....then i also lubed that thing down with "white lithium grease" ..end result..NO NOISE!...dont spray to much grease..it can look nasty...
for the REAR noise----i had tons of knocking noise....we took off the coilovers then added more rubber just like in the front coils....it did not cure the noise...then i rode in the trunk of my car while my friend drove...i saw that the top of the strut was moving up and down(which is normal) but mine was moving very very high and smacking down and making a loud clanking noise.....we then took the rear coils out and took out a huge rubber piece that was up in the top of the strut mount...i added a washer at around the top of the tokico shock.....then i put the rubber thing on...then put the whole coilvoer back together...this EXTRA cushining made it perfect..NO SOUND AT ALL!!!!....my car looks so nice..i am so happy....i have like 1 finger wheel gap all around.....the gc and tokico ride fine on these atlanta streets........i love the handling.....it is WAY !! better than my old eibach springs.........i will have pics after christmas when i get my new digi cam
albert
Old Dec 24, 2002 | 11:36 AM
bump....everyone read this....its important!
Old Jan 1, 2003 | 03:43 PM
sleeper's Avatar
coilvers
thats funny, my kyb/agx-groundcontrol setup doesn't make any noise. some things i can think of that would cause the coilovers to make noise would be if the coilovers were loose on the strut/shocks, the cause of that would be from improper install of the o rings, the bearing that sits on top of the hat may be broken also.
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
