Just ordered drag slicks
Old Sep 9, 2002 | 10:13 AM
Nealoc187's Avatar
SLOW
I just purchased a set of M&H Drag Slicks sized 6.0/26.0-15 to put on my 11lb Mazda Millenia wheels. They are $144 plus shipping, and will be here thursday most likely so I can get them mounted for this saturday and sunday's Battle of the Imports in Chicago. Now I'm just hoping and praying I'm not biting off more than my tranny can chew here... knock on wood
Old Sep 9, 2002 | 10:30 AM
hockeyghst's Avatar
Re: Just ordered drag slicks
are you from or live near chicago??? i am about 40 miles south of chicago.
Old Sep 9, 2002 | 12:00 PM
deezo's Avatar
Good luck!!
Are you going to practice first? I'd say try to get off the line at a lower RPM unless you want to just go all out anyway.
Old Sep 9, 2002 | 03:16 PM
James12345's Avatar
Kinda off topic here...
But what are you running in the 1/4? You the one doin like 14 flats?
Old Sep 9, 2002 | 08:39 PM
Nealoc187's Avatar
SLOW
Re: Re: Just ordered drag slicks
My best time is 14.4. I've been stuck in 14.4s since last november, this will change that. I might be able to pull a high 13 with these.
Hockeyghst I am from southwest michigan.
Old Sep 9, 2002 | 10:44 PM
VQdriver's Avatar
Re: Re: Re: Just ordered drag slicks
i give you 14.1's with those. good luck man. someone's gotta do it! let us know!
Old Sep 10, 2002 | 06:56 AM
My4DSC2000's Avatar
why on earth...
...do you feel you need slicks if youre running 14.4?
Old Sep 10, 2002 | 07:33 AM
MardiGrasMax's Avatar
IMHO 26" is too tall and 6" is too skinney, I got their 24.5"x8.5" and have pulled some 1.9's on them with boost only launching at 5000rpms.
Old Sep 10, 2002 | 10:16 AM
deezo's Avatar
Re: why on earth...
He's striving for 13's NA.
Old Sep 10, 2002 | 10:25 AM
SR20DEN's Avatar
VQ Wizard
24.5 on what rim size? I searched all over and could only find a 22x8-15 for the 15" rims. Anything smaller will not fit on the A33.
26 x6 sounds like a front slick and where did you find that? If your car is lowered you will probably need to remove the plastic wheel wells.
MT will soon be releasing a 24.5x8-15 which will be a perfect size for the Maxima. Althought it could stand to be a 8.5" wide tire instead of 8.0
Old Sep 10, 2002 | 12:42 PM
24.5x8.5x15 on Kosi K1 15x7
The are perfect!
Old Sep 10, 2002 | 12:44 PM
SR20DEN's Avatar
VQ Wizard
The are perfect!
Ok. WTF did you get those?????? I need them!!!!! lol
Old Sep 10, 2002 | 01:06 PM
http://www.intercotire.com/html/hb_drag_slicks.htm
Old Sep 10, 2002 | 01:22 PM
Nealoc187's Avatar
SLOW
I got the size I did because it is a little larger than the stock tire circumferance and will allow me to run through the traps in 3rd gear. I am using 6" wide wheels and there aren't alot of options with a wheel that skinny.
Old Sep 10, 2002 | 01:34 PM
dashingMax's Avatar
HIGH 13's!! Are you running any kind of boost, including Nitrous?
I am going to be there...not to run, but to watch!
Good Luck to you man!
BTW, why aren't you gonna run with your 15" Kosei rims?
Old Sep 10, 2002 | 01:44 PM
Nealoc187's Avatar
SLOW
Re: Re: Re: Re: Just ordered drag slicks
I don't have those 15" Koseis... its a very long story. A certain member of this board took my money and for 5 months never sent the wheels. It has been resolved now.
Also, I did a few calculations. The stock tire (205-65-15) has a circumferance of 80.9" and a diameter of 25.5" This slick has a circumferance of 81.7" and diameter of 26.0, so clearance shouldn't be a problem.
Old Sep 10, 2002 | 03:18 PM
SR20DEN's Avatar
VQ Wizard
I am using the TSW Revo for my slicks. They are one of the few inexpensive wheels that you can get in a 15x7- 5x114. I was told by someone that the Kosei wheels are prone to break.
The 24.5 x 8.5 -15 is the perfect size for the Maxima. I wish I had been able to find those before we got the 22x8 -15's
And what time does the track open on Sunday?
Old Sep 10, 2002 | 03:35 PM
4DRSpeed's Avatar
Project Ruby......
13s Baby!
Nealoc go get those 13s!!
Old Sep 10, 2002 | 07:59 PM
Nealoc187's Avatar
SLOW
What track... RT66 in Chicago? I see you are in NC so I doubt you are talkin about RT66, but the gates open at 10am both days.
Old Sep 10, 2002 | 08:06 PM
SR20DEN's Avatar
VQ Wizard
I was just asking because the gates open at Rockingham at 12pm this Sunday.
Old Sep 11, 2002 | 04:54 AM
JAY25's Avatar
the man needs slicks!!!
traction is our enemy you know that since you ran 12's in your Max!!!look at the vehicles hitting 11's and 12's their trap speeds are from 102-108, if he can get some slicks and improve his 60s he should drop right into the 13s.
JakeOfAllTrades
Oct 5, 2015 10:40 AM
220k+ A32
25
Oct 3, 2015 09:09 PM
bigfrank
Oct 1, 2015 12:51 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Pied
Sep 26, 2015 03:29 PM
