rsb rubbing on brake lines
Old Sep 10, 2002 | 03:24 AM
mingo's Avatar
is anyone having this problem? the capscrews on the stillen rsb are starting to wear on my stainless steel brake lines. the braded steel is starting to rip.. i installed the rear sway bar with the cap screws facing the middle of the car and the buts facing the outside of the car.. is anyone else having the same problem??? it only seems like the driver's side is doing this.. should i worry about my lines bursting anytime soon? it doesn't look tha tbad.
Old Sep 10, 2002 | 03:43 AM
redmaxpa007's Avatar
i SeE what you did therE
how bad was the rubbing?
Old Sep 10, 2002 | 05:03 AM
UMD_MaxSE's Avatar
Got Bent?
hmmm.... my SS brakelines are ok so far, but I need to double check now that you mentioned this.
Old Sep 10, 2002 | 05:04 AM
Confused's Avatar
Permanent Maxima.org Resident
Re: rsb rubbing on brake lines
remedy immediately before it burst and you have NO BRAKES.
Old Sep 10, 2002 | 09:07 AM
PCGuRu2K's Avatar
Yeah definitely check it out.. Mines bursted on me when I was on the rode. That was some scary ****!!!! I think I fixed mines by reversing the bolts...
Old Sep 10, 2002 | 03:49 PM
mingo's Avatar
if i reverse the bolts it'll rub even more.. it just seems like the cap screw severed the stainless steel.. it hasn't rubbed that far through yet.. how much is it for just ONE stainless steel brake line?
Old Sep 10, 2002 | 05:15 PM
PCGuRu2K's Avatar
I don't think you can buy just one. They come in a pack of 4. I had to buy a whole set for mines. Got it from Phuong at Eatricezone So I only used the rear. I still have a pair for the fronts brand new.
Old Sep 10, 2002 | 05:24 PM
Tanman's Avatar
Maybe wrap the head of the cap screw with some duct tape. Conversely, you could wrap the brake line with tape or with rubber heater hose to protect it.
Old Sep 10, 2002 | 05:38 PM
SLC I30t's Avatar
your brake lines should be sticking like a good inch away from the control arm. Or do they not fit in that mounting bracket that the rubber ones did?
Old Sep 10, 2002 | 06:37 PM
Tanman's Avatar
With the stillen RSB, the upper right bolt is like a mm or 2 from the brake line. It will rub occassionally.
Old Sep 10, 2002 | 06:41 PM
UMD_MaxSE's Avatar
Got Bent?
hmmm.... my RSB brackets are kind of close to the brake lines also... I think to be safe you should try using some rubber hose around part of the brake lines or the RSB bracket.
Old Sep 10, 2002 | 06:42 PM
SLC I30t's Avatar
It shouldn't if you used the spacers, mine have great clearance.
Old Sep 10, 2002 | 09:01 PM
mingo's Avatar
the spacers are for the handbrake cable..
i figured what was wrong... it was bad installation.. when i installed the steel braded lines i mounted them wrong (the part that bolts the hard hose to the brake lines). the brake lines are suppose to be slightly angled towards the middle of the car.. i'm going to fix it tonight.. thanx everybody for your feedback
-daniel
Old Sep 11, 2002 | 11:36 AM
97MaxGurl's Avatar
Chick specializing in rounding up 100+ Maximas
took mine off altogether
Old Sep 11, 2002 | 10:42 PM
mingo's Avatar
wasn't bad install... it just didnt' work right.. i bent the bracket that holds the brake lines (the one with the clip) now the brake line clears the bolt by over 1"
Old Sep 12, 2002 | 03:38 AM
TurDz's Avatar
to be safe, you should maybe wrap up the SS brakeline with duct tape or electical tape. Then you can see if it still touches or rubs. does that sound good?
Old Sep 12, 2002 | 03:43 AM
mingo's Avatar
it for sure clears it by alot now.. i just need to get another set of lines just incase that sucker decides to burst on me.. OOOoOo that means my freshly painted rear bumper would hafta be repainted.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
