Might have problem with MSD window switch. Need help
Old Sep 15, 2002 | 03:06 PM
DOM's Avatar
DOM
I have had the msd window switch modified for a one cylinder application. I bought autometer rpm pills because that is all I could find on summitracing. I did not try a run with nitrous because my bottle is empty. Now when I tested it with GarthG, the car no longer has that 'twong' sound it had before the switch when it was activated. Can anyone give me any suggestions? Are these autometer rpm pills not compatible with the msd rpm window switch?
Old Sep 15, 2002 | 04:25 PM
1MAX2NV's Avatar
Tell us how you wired it?
Old Sep 15, 2002 | 06:33 PM
GarthG's Avatar
Took switched power and hooked it to the red (checked to make sure it turns on and off with switch)
Ground Wire hooked to the battery (assume grounded correctly as everything else in the car works perfectly)
Took the lead that needed a pulse and hooked it to purple w/white stripe wire on cyl 4 (as that was easiest and I don't think it should matter which cylinder as it just needs a pulse.) (Looks to be pulsing correctly)
The 1.5 Amp max out went to where the switched power used to go. (can't check if it is turning on any ideas on testing would be great on how to check this).
Old Sep 16, 2002 | 01:22 PM
DOM's Avatar
DOM
Please help. I don't want to blow up my car because this thing isn't working
Old Sep 16, 2002 | 01:26 PM
BriGuyMax's Avatar
you don't have to worry about that....if it's not "working" then your nitrous won't activate at all unless you bypass the Window switch...
Old Sep 16, 2002 | 07:32 PM
20th maxstyle's Avatar
Bottles are for babies
Old Sep 16, 2002 | 11:33 PM
GarthG's Avatar
Can we please try and keep this topic free from comments like this. . . Some memebers choose to use nitrous, some don't. . . If you don't know anything about this please stay out of the thread. Thanks.
Old Sep 17, 2002 | 10:58 AM
irvine78's Avatar
Old Sep 17, 2002 | 12:15 PM
DOM's Avatar
DOM
I am a baby. I love bottles. Now, can anyone help?
Old Sep 20, 2002 | 01:23 AM
DOM's Avatar
DOM
Geez. Maybe I should have written the word TURBO just to get people to look at it
Old Sep 20, 2002 | 05:54 AM
1MAX2NV's Avatar
I finally read what Garth G wrote...i didn't know he was working on this with you. The yellow wire DOES NOT provide +12V...so that's your problem. It's not suppose to give +12V switched power. Look at Figure 5, from the MSD installation instruction. The yellow suppose to provide switched "GROUND". Hook the yellow wire to the ground of your main nitrous relay.
Old Sep 20, 2002 | 10:01 AM
jdmmax's Avatar
gah gah goo goo
no need to hate...........heheh j/k
Old Sep 20, 2002 | 05:16 PM
GarthG's Avatar
Thank you for an answer. . . I should have read it more carefully. That is where the problem is.
James92SE
Oct 8, 2015 04:57 PM
thenewguyy
Sep 12, 2015 11:12 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
