Detonation on 100 shot nitrous :advice (long)
#41
Originally posted by MardiGrasMax
How many miles were on your motor when it blew?
#42
Originally posted by BriGuyMax
96,000....I'm suspecting it was injector related....POSSIBLY...and this is just a possibility...it had to do with un-even nitrous distribution as the NOS dry kit was not originally designed to run a 100-shot.....
#43
I ran a 100 shot for along time and never had a problem. Yes the kit for a Maxima is sold by NOS as a 60hp set up. before I installed the kit I talked to their tech department about it, they indicated that your fuel injectors must be in perfect working order. I told them my car had only a few thousand miles on it and they said it should be fine but that I should consider getting the fuel injectors cleaned every so often. Of course I never had them cleaned. When I started to progress up from the 60 shot to the 100 I was worried about running up the fuel pressure so high, I had a conversation with Kyle at SGP Racing (300ZTT shop) and he told me that ~90psi was the danger zone for the type of injectors in the 4th gen Max. So I headed his word and never exceded 90psi. I guess issue with the dry kits is injector failure, on lower milage motors its dosent seem to be an issue, on high milage motors it does. I guess the moral of the story is if you have high milage, IMHO over 75k, and you want to crank up some dry nitrous get a wet kit or have your injectors replaced and do a dry kit.
Other things to allways be sure of is BOTTLE PRESSURE!!! On a 110 degree day bottle pressure is sure to be over 1200psi, this will cause catastrophic leanness if you dont compensate with more fuel, dry or wet. On hot days I take a wet rag and lay it over the bottle with my trunk open when i am not racing, this keps the temps under control. And allways check your plugs, tiney black and silver specs on the white ceramic insulator is never a good sign.
#44
Originally posted by SR20DEN
The NOS dry kits are designed to handle upto a 175 (crank) shot.
#45
What happend to you SUCKS. I'm not trying to start ****.
#47
It's so true about the bottle pressure. 15 mins with my bottle warmer on bypassing the temp control thingy. My bottle pressure would reach 1200psi.
#49
#51
ok so just did the compression test. these are the results.
as before mentioned this is how i counted my cylinders.
6 5 4
1 2 3
here are the numbers
180 170 170
160 160 170
i had bad plugs in cylinders 1,2,3,4
cylinders 6,5 were fine.
any one have any suggestions??
oh and i have ecu code im gonna check tomorrow just wondering if anyone ever had a ecu code after a compression check??????
6 5 4
1 2 3
180 170 170
160 160 170
#52
6 5 4
1 2 3
180 170 170
160 160 170
6 5 4
1 2 3
180 170 170
160 160 170
1 3 5
2 4 6
And that would make it 2,4,6,5
2 and 4 are below spec but will be fine. Just put in new plugs and be on your way.
06-06-2017 02:01 PM
knight_yyz
11-01-2015 01:34 PM
Andy29
09-29-2015 05:32 AM
