neon underbody kit= overdrive/tranny problem
Old Sep 25, 2002 | 06:08 AM
1HOTMAX's Avatar
when i have my street glow gold series neon underbody kit on while the car is running/for some reason my over drive keeps on flashing on and off constantly and the tranny feels sluggish when i have my neons on. when i turn them off, re-start the car, the o/d flashes 10x and the car runs fine again.
i have no idea why.
1 month ago i thought it was the torque converter and had nissan look at it but now i finally linked it to the problem.
any idea why it's doing this?
Old Sep 25, 2002 | 08:08 AM
maximumsportZ's Avatar
Lives in a 350Z
if when you start your car the OD light flashes that means its sending out an engine code... there might be a problem with your tranny.. I'm not sure what code or what problem it is, but I remember reading on the org about someone having the exact same problem.. do a search : Overdrive blinking..
Old Sep 25, 2002 | 08:34 AM
NickStam's Avatar
neon underbody kit = car appearence problem
Old Sep 25, 2002 | 09:35 AM
PCGuRu2K's Avatar
Re: neon underbody kit= overdrive/tranny problem
i have no idea why.
I had Jeff install my Blue Gold Series on Mon. So far no weird problems or flashing lights.. I'll let you know if I do though..
Old Sep 25, 2002 | 10:57 AM
thebigsadler's Avatar
Re: Re: neon underbody kit= overdrive/tranny problem
<~~~~~ Had O/D Flash before tranny died. Luckily 60k powertrain fixed it with a new tranny.
Old Sep 25, 2002 | 07:05 PM
ny96max's Avatar
Thai, please dont tell me you tapped off any harness's for power to your underbody neons. They draw alot of power and need to be ran directly off the battery, with a fuse of course and also grounded either to the batter or an existing ground point *hint*
Ant
Old Sep 25, 2002 | 08:24 PM
1MAX2NV's Avatar
You might have tranny shift soleniod problems.
Old Sep 26, 2002 | 06:20 AM
1HOTMAX's Avatar
dammmmmm
it only does it when i'm alone.........when i'm at the dealer/ she behaves soooooooo nice????
Old Sep 26, 2002 | 06:34 AM
Bags's Avatar
VG Ridah's Biatch Hoe
Re: dammmmmm
check the ECU and TCU codes and see what it says
Mar 12, 2020 12:06 AM
Jamie Bolus
Sep 13, 2015 05:56 PM
slowlifer
Sep 8, 2015 05:53 AM
A32goldylocks
Sep 2, 2015 06:39 AM
