Confused about these Indiglow gauges!!
Old Oct 1, 2002 | 09:28 PM
xsp00kyx's Avatar
first of all do you guys like the gauges at www.custommaxima.com for my 99 se?? anyways i checked them and they came out to about 70 bucks!!
now in ebay they sell them too but cheaper, and i'm just wondering if they are the same quality as custommaxima??
Old Oct 1, 2002 | 09:40 PM
mb1's Avatar
mb1
Re: Confused about these Indiglow gauges!!
I got mine 2 color from procarparts on ebay. work great, no problems. Look in sig.
Old Oct 11, 2002 | 12:09 PM
Sway1331's Avatar
Re: Re: Confused about these Indiglow gauges!!
the gauges from procarparts are they good quality? im right in assuming they are replacements not just overlays?
A couple more questions
1) how do you remove the black or white part in your stock cluster?
2) where did you run the power from? and do they work with your dimmer switch?
3) was it hard to get the needles off and on and still work properly?
thanks for your time
Old Oct 11, 2002 | 12:39 PM
NightRider's Avatar
Re: Re: Re: Confused about these Indiglow gauges!!
I believe they are all the same quality.
All indiglo and reverse indiglo guages available for the Maxima are overlays.
You don't. The replacements just lay over top of them.
You run the power from the BLUE power wire coming off of the dimmer switch. They will work independently on their own dimmer switch that is included.
There is no need to remove the needles to install the guages. The slide over the needles.
You are very welcome.
Old Oct 11, 2002 | 12:49 PM
redmaxpa007's Avatar
i SeE what you did therE
www.maximadriver.com
go to the how 2 section
there is a write up on installing them.. i used it to my indiglos.. very helpful info..
Old Oct 11, 2002 | 01:34 PM
JAIMECBR900's Avatar
When installing, remember you will have to figure out something (some have used glue) to keep the indiglos as flat as possible to keep from needles sticking.
Old Oct 11, 2002 | 01:35 PM
like mine do...
and to you..
Old Oct 11, 2002 | 02:17 PM
cmac95gxe's Avatar
Maximaniac
I got my indiglo gauges from www.procarparts.com also and I think they are good quality. I'm very happy with them. You can also use two-sided tape instead of glue to keep your needles from sticking.
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
AboveDaCloudz
Oct 8, 2015 11:25 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
