Clicking from calipers...??
Old Oct 3, 2002 | 09:08 AM
Chebosto's Avatar
RIceD OuT moDErAtor
I'm getting clicking noises at low speeds from my driver side caliper. freakin brand new brembos.
but i've heard that this is a common problem for some 5th genners too.. anyone know what it is?
is it the CV joint going? possibly?
hm..
only heard this when i put in my new brakes.
Old Oct 3, 2002 | 09:12 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Re: Clicking from calipers...??
You heard from mingo, or from other 5th gen owners?
Old Oct 3, 2002 | 09:14 AM
thebigsadler's Avatar
Re: Re: Clicking from calipers...??
Originally posted by Y2KevSE
You heard from mingo, or from us 5th gen owners?
cheston I have the same issue, only on drivers side, it started happening after my alignment, and after I got new SS lines put on.. I have no clue, braking didn't seem to be affected.
when you are just sitting in the car parked, if you press the brake pedal down can you hear it click then?
Old Oct 3, 2002 | 09:35 AM
2k2kev's Avatar
It's chrome alright...
did you forget to take the baseball cards out of the spokes??
Old Oct 3, 2002 | 10:12 AM
redmaxpa007's Avatar
i SeE what you did therE
Old Oct 3, 2002 | 11:08 AM
Chebosto's Avatar
RIceD OuT moDErAtor
Re: Re: Re: Clicking from calipers...??
Yea. its when i press down on the pedal .
i think it maybe a line issue. im gonna rebleed the brakes.
maybe that's it.
Old Oct 3, 2002 | 12:19 PM
Re: Re: Re: Re: Clicking from calipers...??
definitely let me know if that fixes it.. didnt even think about that.
Old Oct 3, 2002 | 02:11 PM
Chebosto's Avatar
RIceD OuT moDErAtor
Re: Re: Re: Re: Re: Clicking from calipers...??
these are new calipers. and they're tested before they were sent out.
i didnt have speedbleeders (one way valve) for these calipers yet, so i had to bleed them with my friend who didnt really know how, although the pedal is pretty firm, perhaps there is still air inside.
Old Oct 3, 2002 | 02:21 PM
joaquink's Avatar
¿Hablas Español?
Re: Re: Re: Re: Re: Re: Clicking from calipers...??
I have the same symptom and have figured it was the result of air in
the system as well. I've had this on my to-do list for quite a few
weekends but am still hopeful I'll get to it on this one. It will be
interesting to see how this works out. I have the Wilwood setup so
it seems likely that the common symptom would have to result from a
common source; brake fluid is about the only thing we'd have in
common for the brakes.
Cheers,
JK
Old Oct 3, 2002 | 03:18 PM
Re: Re: Re: Re: Re: Re: Re: Clicking from calipers...??
<~~~wilwoods
Old Oct 3, 2002 | 06:59 PM
gepetto's Avatar
I have this problem too. Kind of like a repeated clicking at low speeds on the brakes. Has anyone tried the bleeding yet? If so, I'll do it this weekend. Thanks for the help.
P.S. I only got this after my new brake install too.
Old Oct 5, 2002 | 12:30 AM
Chebosto's Avatar
RIceD OuT moDErAtor
FYI, the clicking is for sure the pistons.
freakin A.
i will rebleed this weekend.
Old Oct 5, 2002 | 09:29 AM
Y2KevSE's Avatar
Did you know the pistons are magnetic? They pull the pads back when you let go the brakes, so............. pull back *click* (not as audible), push forward *click*, pull back *click* (not as audible), push forward *click*, pull back *click* (not as audible), push forward *click*...
Just a guess.
Old Oct 5, 2002 | 09:57 AM
matt calder's Avatar
Just a guess.
Duh everyone and their brother knew that already.
Old Oct 5, 2002 | 10:12 AM
yeah... a....... everyone knew ..........that
Old Oct 5, 2002 | 11:11 PM
Chebosto's Avatar
RIceD OuT moDErAtor
UPDATE!
CLICKING IS GONE!
re-bled the brakes today. no more noise.
yay
Old Oct 5, 2002 | 11:35 PM
UPDATE!
CLICKING IS GONE!
yay
i talked to a guy today and he said if bleeding the lines doesnt work he is going to shave the edges of my brake pads, we'll see..
thanks a lot.. glad to hear you found it!
Old Oct 6, 2002 | 10:16 AM
gepetto's Avatar
Man I don't want to have to go out and rebleed my brakes. Since I'm calling the place that did the job cause they already screwed somethin up, I'll have it done there.
Old Oct 6, 2002 | 07:09 PM
Chebosto's Avatar
RIceD OuT moDErAtor
bleeding is pretty easy
just turn car on,
Pump once, twice, three times, HOLD pedal down,
then open the bleed valve, let it go until you see a constant stream of fluid while watching the resivoir, tighten, then release pedal.
repeat.
Old Oct 8, 2002 | 05:29 AM
Albertt's Avatar
Cheston...you feel that it's air in the lines? >>
I've had the same problem...seems to come from the rear brakes. They clink, not always, but when i apply pressure the pedal. A freind mentioned pad to rotor spacing needing to be re-adjusted.
Al
jmlee44
Oct 2, 2022 02:13 PM
mclasser
Sep 24, 2015 11:57 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
ajahearn
Sep 19, 2015 03:03 PM
bennuss
Sep 11, 2015 05:55 AM
