AGX's and hydroplaneing
Old Oct 11, 2002 | 07:38 AM
PhatBastard's Avatar
The wet season has started here in Louisiana. I installed my AGX's back in May and this is the first time since then that we have had rain heavy enough to stand on the roads.
Last night I thought I was going to loose the front end when I hit about a 1/2 inch of water on the interstate at about 50mph.
I don't recall this being a problem with my old oem struts/shocks with the same tires that I have now.
Has anyone experienced this with the AGX's? I'm set at 2/4 right now.
Would a harder or softer setting help with this problem?
Vitals: '95 SE Autotragic, AGX & OEM Springs, 16x6.5 Moda R2's, Michelin Pilot XGT H4's (about 15k miles/tread is good) 225/55 R16.
Old Oct 11, 2002 | 08:10 AM
njmaxseltd's Avatar
Your tires are to blame, not your struts. Harder or softer strut settings wount help channel water out from under your tires. How many miles are on your rubber, and what brand/size are they?
Tom
Old Oct 11, 2002 | 08:15 AM
deezo's Avatar
Buy tires with better grip and wider channels to prevent hydroplaning.
Old Oct 11, 2002 | 08:24 AM
redmaxpa007's Avatar
i SeE what you did therE
tires
Old Oct 11, 2002 | 10:48 AM
NotNew!!NewSN!!'s Avatar
stiffer the suspension= the more even the distribution of weight on TIRES
Old Oct 11, 2002 | 10:50 AM
Redmax's Avatar
Redlinemax Owner
need new tires
Old Oct 11, 2002 | 11:10 AM
chinaonnitrous1's Avatar
you need new strut bearings!
Old Oct 11, 2002 | 11:13 AM
Ramius83
Old Oct 11, 2002 | 12:11 PM
Dave B's Avatar
Not DAVEB the parts guy
1/2" of water? Ummmm....how about driving slower.
Dave
Old Oct 11, 2002 | 12:21 PM
95Max's Avatar
Slick road surface....water bring up oils
Tire pressure
Alignment
Old Oct 11, 2002 | 12:23 PM
Evil S14's Avatar
i dont think this would matter if he was just driving in a straight line. Most likely ur tires, when u get a wider profile your more prone to hydroplane. and some tires just arent made for the rain, mostly the mi performance ones
Old Oct 12, 2002 | 07:21 AM
Originally posted by njmaxseltd
Your tires are to blame...
Old Oct 12, 2002 | 07:23 AM
Dave
Thanks Dave for your valuable input.
Old Oct 12, 2002 | 07:34 AM
seven's Avatar
hey phatbastard, you live in Baton Rouge?
Old Oct 12, 2002 | 07:41 AM
Lime's Avatar
stiffer suspension should actually help keep the car on the road. Sounds like tires are to blame.
Maxima_Joe
Nov 25, 2015 08:19 AM
maxima-junky
Oct 7, 2015 06:13 PM
Maxima_Joe
Aug 27, 2015 12:01 AM
RussMaxManiac
19
Aug 31, 2001 09:02 AM
