Hyperground grounding points for 5th gen
Ok, the instructions in the kit aren't very useful because I think they were written for a Honda .
I've seen some other posts for 4th gens, but none for the 5th gen.
I've identified 4 of the 5 grounding points:
1) passenger side chassis
2) stock grounding bolt between intake manifold and valve cover
3) alternator grounding point (transmission or cylinder block)
4) stock battery grounding point (cylinder head) (black line is stock)
5) driver side chassis
I haven't been able to actually identify the grounding point for #3. I think I'll have to remove the SC piping to get to it from the top of the engine.
For #4, I'll have to access it from under the car since the SC piping is in the way. Even on stock engines, it's hard to see the bolt from the top of the engine.
If anyone could pinpoint the alternator\transmission\cylinder block bolt (a picture would be great), it would be appreciated.
well, you might not even have to go through that much trouble at all. Instead of the three wires meeting at your ground #4, you can ground them off your upper intake manifold bolt. Even better, if you look on the front of you manifold and to the left, you'll see the 2 stock 14 gauge ground wires grounded there. Ground the wires there (we'll call that Ground i), use one ground wire to ground from Ground i to your ground #4 (engine block). My ground 2 is also on the timing chain cover, but further back towards the side of the upper intake manifold. I wish I could upload pics, but hopefully you can get a good enough idea from my descriptions.
Originally posted by krazyd
What does a hyperground system actually do? I've seen tons of posts about these system, but I don't know what they are/do.
I was the one who had the kit tested and dyno'd on my 97 Maxima. I have a dyno sheet floating around on the .org if you want to take a look. I'd like to see someone else dyno the gains just to make sure my car's not just a flop. Sun Auto only tests the kit on brand new cars and they've shown decent gains from 2-8HP. I gained a lot!!! I think you could easily make the kit yourself for $30 or so, but the Hyperground wires look really nice. I have an extra set if you're interested.
Ground point #4 is where the stock battery wire is grounded.
I'm not sure if the 5th gen is exactly the same as the 4th gen, but on mine, grounding point #2 has two ground bolts with small gauge wires grounded there. That's not the same as your Ground i, right?
Originally posted by Tanman
Where roughly on my picture is the "upper intake manifold bolt"?
On my 97, there are a couple of bolts that tie the upper intake manifold to the lower piece. I just realized that the USVI must be different. I have two ground points between the blue drawn line and the 2 black hoses in your picture. If you ignition coils ground at your point#2 use those and disregard my "Ground i" (the 4th gen must be different).
I'm going to check for existing ground points in the area, but if anyone knows where the bolt it, that'd be helpful .
Finkle
09-27-2015 09:53 PM
Cant_Get_Ryte
08-28-2015 06:41 AM
