EVAP Sensor....
Old Oct 28, 2002 | 08:44 AM
Swafford98's Avatar
EVAP Sensor....
I replaced the EVAP purge valve sensor on Saturday and today(Monday) the CEL came back on with the same code. Does anyone know what causes this to trip the light and why it would go bad if i just replaced it two days ago?
any help would be greatly appreciated.
Old Oct 28, 2002 | 10:10 AM
Curt Deiner's Avatar
Re: EVAP Sensor....
What number code did you get? I had to replace my EVAP canister valve.
Old Oct 28, 2002 | 10:16 AM
Swafford98's Avatar
0111.. i was told that this code is for the evap canister valve.
I have a 1998 SE
Old Oct 28, 2002 | 10:28 AM
I have a 1998 SE
The "decoder" says: EVAP control system/Flow
Mine pointed to the purge valve located in front of the canister which is behind the left rear wheel. It was stuck, full of sand and dirt. My codes were 0903 and 0705. Don't know what to tell you. You only got one code?
Old Oct 28, 2002 | 10:35 AM
Swafford98's Avatar
yes only one code. Flashes the same thing over and over.
the EVAP flow.. is that for my code of 0111??
Old Oct 28, 2002 | 10:41 AM
Yes, see the sticky thread in the 4th Gen forum. "ECU fault code diagnosis" Maybe check all your vacuum lines are connected?
Old Oct 28, 2002 | 02:33 PM
JAIMECBR900's Avatar
Hey bud, check the vaccum hoses that go from the canister to the intake plenum. I had the same type of code and it ended up being a vaccum hose that was all messed up. I replaced it and now no CEL and the car idles great.
Old Oct 28, 2002 | 02:34 PM
My bad, you know what? I think I read somewhere that for your car the solenoid is electrical, not vaccum controlled. I'll check into that and let you know.
tseng1023
Oct 15, 2015 08:30 AM
homeofbacon
Sep 23, 2015 07:17 PM
220k+ A32
Sep 11, 2015 02:18 AM
dcam0326
Sep 7, 2015 07:26 AM
doobadoo
Aug 15, 2015 06:43 PM
