Does a custom CAI with boost do that much?
Old Oct 29, 2002 | 09:07 AM
nymjayjay's Avatar
I was wondering if the custom CAI with boost is really worth it. I hear that finding all the pieces are a pain in the a$$ also. People with boost and a custom CAI is it worth it, and if so where did you get all your parts/pieces from for your CAI?
Jay
Old Oct 29, 2002 | 09:25 AM
Sprint's Avatar
yes
Old Oct 29, 2002 | 09:32 AM
Tanman's Avatar
I've been gathering parts for the SC CAI. All you need is a filter, hose, clamps, hose coupler (more stuff for the 5th gen). Check Chesbosto's write-up for it for details. With all the WAI vs CAI threads lately, it's getting harder to say which is better. However, boosted cars should have different results.
Old Oct 29, 2002 | 10:54 AM
[maxi-overdose]'s Avatar
Re: Does a custom CAI with boost do that much?
Jay
Kevin got 1 additional psi after the install.
Old Oct 29, 2002 | 10:59 AM
nymjayjay's Avatar
Re: Re: Does a custom CAI with boost do that much?
I am doing it this weekend and hopefully I will get an additional 1PSI also. I wont know really cause I am doing the 3.25" pulley and the CAI at the same time The 3.25" pulley is suposed to give 8-9PSi right?
I also wonder what the HP gain is on the custom CAI....
Old Oct 29, 2002 | 11:11 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Re: Re: Re: Does a custom CAI with boost do that much?
Don't count on the same 1psi gain, because it isn't the same setup! Kev's CAI setup eliminated that long azz pipe that ran all the way across the engine bay, which 4th gens. don't have.
I think your biggest gain will be consistency and torque down low when the ambient temps climb.
Old Oct 29, 2002 | 11:14 AM
nymjayjay's Avatar
Re: Re: Re: Re: Does a custom CAI with boost do that much?
thats a good enough gain for me, any gain is a good gain when it comes to boost
Old Oct 29, 2002 | 12:26 PM
Bags's Avatar
VG Ridah's Biatch Hoe
well here is a post with some info on how much boost you *should* get from each pulley..https://maxima.org/forums/showthread...5&pagenumber=2
Old Oct 29, 2002 | 12:27 PM
nymjayjay's Avatar
thanks man
Old Oct 29, 2002 | 12:41 PM
Tanman's Avatar
Remember that you will probably have to remove the windshield washer fluid reservoir if you install the SC CAI. If you find another place to install the reservoir, please let us know. Most guys just leave it out. Here in Texas, you need to use the windshield washer, so I'm trying to figure out where to put it.
Old Oct 29, 2002 | 12:46 PM
Cumalot's Avatar
That's the problem. The way my SC CAI is setup, there's no room to put the windshield washer reservoir. I'm not totally sure if the SC CAI is worth it. I'm only getting 8psi right now on my V1 SC. Not sure if that has to do with the belt not being tight enough(which I'm in the process of retightening it), leaking Greddy BOV, or whatever. I'm thinking of going back to the pancake filter(probabably going to get a larger size one though)and put the washer reservoir back in.
Old Oct 29, 2002 | 12:47 PM
SuDZ's Avatar
Is it completely in the way or does it just not have enough clearence? I am just curious that if it did not have enough clearence maybe you could try findding a smaller resevoir off of some other car and try to bolt that in. Just curious.
I know on Honda's that this was a problem with the CAI on some cars, there is now a company that makes a smaller resevoir to accomodate this. Maybe a group deal through them wouldd make them produce a few for you guys.
SuDZ
Old Oct 29, 2002 | 12:48 PM
nymjayjay's Avatar
See I really do not use my washers that much only in the winter sometimes to get the kickup dirty water off my windshield.
Old Oct 29, 2002 | 01:15 PM
Bags's Avatar
thanks man
your welcome
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Sep 27, 2015 08:37 AM
