Help with bearing questions for VQ 5speed thanks in advance
Old Nov 5, 2002 | 01:47 PM
ivolley's Avatar
Hello guys I need help from you tranny experts. **ERIC WONG**I have a noise that goes away when I engage the clutch. The noise is pronounced in 1st and second but starts to lessen in 3rd and is gone by fourth. I am sure this is the INPUT shaft bearing. Well the problem is I understand that there are other bearing in the tranny that could cause this noise -NOT THE THROW OUT BEARING- I want to replace all the bearings The tranny guy told me to ask for a bearing kit from Nissan but Nissan does not sell a "bearing Kit" so Nissan faxed me a diagram with numbers on them and I am trying to identify what/where these 2 or 3 bearings are. The Tranny tech said there are 2 or three bearing besides the throw out bearing ( I had that replaced 3 months ago) If someone has this diagram or has a FSM I would great appreciate it. If not can some tell me the name of these 2 or 3 bearings. It sounds like I can get these bearings for under $100 so I will have them all replaced. I do apologize if this has been posted I live by the search button but I am @ a new gig and I am should not be here
I cannot run an extensive search but when I get home this evening I will.
Thanks,
Pat
Old Nov 5, 2002 | 02:43 PM
joaquink's Avatar
¿Hablas Español?
Re: Help with bearing questions for VQ 5speed thanks in advance
I'm having essentially the same problem.
The short of the above is that it was the mainshaft rear
bearing and differential side bearing that went bad the
first time. Now the sound is back and we have no idea so
apart it comes once again.
Also, do you have a Quaife differential in there?
Old Nov 5, 2002 | 03:14 PM
Bags's Avatar
VG Ridah's Biatch Hoe
ok Pat..
These are the bearings
input shaft front bearing
input shaft rear bearing
mainshaft front bearing
mainshaft rear bearing
If you need my FSM let me know
Old Nov 5, 2002 | 04:10 PM
ivolley's Avatar
Re: Re: Help with bearing questions for VQ 5speed thanks in advance
Thanks for the info no Quaife differential here. Sounds like he had it replaced for a great price, good luck.
Old Nov 5, 2002 | 04:14 PM
ivolley's Avatar
Originally posted by bags533
ok Pat..
BAGGY BOY!!!!!
I<3 A32's
Sep 10, 2015 11:07 AM
jfl330
Sep 4, 2015 01:44 PM
boomerbrian
Sep 4, 2015 08:25 AM
Lowered_a33
Sep 1, 2015 07:49 PM
