Engine Code 0705
Engine Code 0705
I have a code 0705. The Code reads (EVAP system leak.) I have search high and low trying to trace the hoses from the EVAP Canister with no luck. Not only have I not found the canister but also I have check and double-check all of the vacuum hoses under the hood. I did find one hose that was off from a line under the throttle body to the CAI, the hose was replaced and rest the ECU, but I got the code back today so problem is still there. Anyone ever had this code or similar problem? It a 96 Without California emissions stuff.
Re: Engine Code 0705
derekinthez
Nov 13, 2022 04:00 PM
