60k service worth it?
Old Nov 16, 2002 | 07:16 AM
flyer's Avatar
I bought my car at 77k miles so I have no idea if the previous owner did the 60k service on it or not?
Is it worth my scoffing up around $400 for the 60k mile service at the dealership that involves a coolant change, spark plugs, filter etc and an inspection of a few other things.
Or should I just change the spark plugs, and change other things as and when needed?
Old Nov 16, 2002 | 07:31 AM
ereet's Avatar
Re: 60k service worth it?
After doing the SC install, I changed pretty much everything that would be during a service myself. Spark plugs, fuel/oil filters, oil, coolant, power steering, blablablabla. If you're confident enough, do it yourself. Not only will you save a TON of money, but you'll feel better about your car running well too
Old Nov 16, 2002 | 12:29 PM
iregula's Avatar
yeh i would say the same thing....its a lot of money but maintenance is the best mod
Old Nov 16, 2002 | 05:16 PM
Frank Fontaine's Avatar
If there's any service worth doing that'd be the one. Unfortunately our plugs (4th gen) are only good for 60k not 100k. Get a coupon and the service would be maybe $325. For me it's not cost-effective to diy the way brakes are. That's coming from a guy who gets up 5:30 am to work on the lawn.......
Old Nov 16, 2002 | 09:29 PM
ThurzNite's Avatar
i'm looking at the flyer from my local nissan for 30k service.
lube: doors, locks, hinges, chassis
adjust: tire pressure, rotate tires, brakes, clutch , timing, CO level, idle speed
inspect/check: all fluid levels, all belts, all signals, all lights, all hoses, wier blades, brakes, battery, plug wires, rotor, ignition cap, exhaust system, air conditioner, analyze engine, cooling system, o2 sensor
replace: engine oil, oil filter, anti-corrosive battery terminal pads, engine coolant, air filter, fuel filter, spark plugs (add $150 for platinum v6), fuel injection service, hydraulic brake fluid, clutch fluid, engine oil flush, tranny fluid, diff fluid.
For $430, I dunno if it's worth the $. Stuff I can't or don't want to do myself (cuz lack of knowledge or Consult): timing, co level, idle speed, air conditiner, analyze engine, cooling system, o2 sensor, fuel injection serivce, engine oil flush. For those services, I'll pay 200-250...all the other junk, I can do myself. Anyways...I'm saving up to do the preventative maintenance. Got another 5k to go.
Jae
my03maxima
Jul 28, 2024 07:40 AM
Forge277
Jun 13, 2016 09:26 PM
RealityCheck
Oct 2, 2015 06:34 PM
homewrecker
Sep 24, 2015 07:01 PM
Jay556
Sep 12, 2015 05:50 PM
